I recently purchased this Old Solid Round Stone Approximately 9.072kg, 17.78W X 17.78H & Circumference 60.69cm at an estate sale and not sure what it is but the price was right. Does anyone know what this may be?
Thanks
Dolomite balls were used to make the pyramids and other large megalithic structures.   Bang two stones together and one does not need iron or steel hammers and chisels.  It has been shown that working sitting in quarry trenches can cut through anything using similar stones.
In a leather sling, they also work well for catapult ammunition.
Such things also make good ballast stones.  They pack well.
-julie
Current Build:  Forester
Planned Models down the line:
Saginaw
Contra Costa/Solano Ferries
Nemi Ships
Gjøa
Polar ships  S.Y. Aurora,  Endurance.
There are various other options in addition to the ones mentioned already:
- A stone from a so-called glacier-mill - a natural phenomenon whereby a rock swirls around a sort of meltwater syphon under a glacier, creating a funnel-shaped feature and eventually an almost perfect sphere.
- An early canon-ball, but it doesn't seem to be shaped well enough for that
- A well-used stone from a ball-mill - a rotating steel cylinder in which several stones like this are placed to crush something; as the material seems to be limestone from the look of it, it would not be too hard and could crush probably only organic material.
In what part of the world was it found?
Edited by wefalck
