                                   Hi to all you boat builders :)
                             Should I have a garboard strake on hull?
                             I'm currently planking the Hermione la Fayette - scale I=89 AL. All the planks for the hull
                    are a measurement of 2mm x 5mm but no such garboard strake included in the kit. I have built
                    the Bluenose-// AL, witch there was no problem at all.
                             The Hermione.... is a bluff bowed French frigate  witch I thought should have a garboard
                    strake?          There is no such garboard plank in the kit so i'm baffled as to weather it should?
        also if yes should I make one from that sized plank?
                                                          Your answers to this question would be most helpful     :)
        Kier
                  Warning!!!!!   i'm still learning :(
Saving for: HMS Vanguard...Victory models.
finished: Bluenose11...Billing Boats... (sorry no log.
Greetings Kier,
I agree with Joel. You could say that garboard is more about a specific location than a planking width. The garboard may be cut from a wider stock to facilitate fitment to the hull framing.
wq3296
Greetings Kier,
In my opinion, so long as the stock you have is the right thickness, I wouldn't worry about the width. You can always edge glue a couple of planks together to form a wider plank from which to cut the garboard. Kier, don't fixate on the idea that the garboarb must be wider. At model scale it is perfectly acceptable to use whatever width is suitable to do the job.
wq3296
