Unfortunately, I am unable to recall all the notes I made about this model, but will do my best to recall what I can. I started this model about a year or so ago. The planking patterns were quite difficult to install - this was mainly due to the thickness of the planking pattern as well as the unusual shape of the hull of the Mars. It was bluff ended at the bow and as the hull went lower it had more of a schooner shape hull. I used cherry veneer as the second planking and was pleased with the result. After the first planking, there was a fair bit of sanding that had to be done and as usual filler was used to even out the hull prior to planking. The hull was planked with boxwood and treenails installed using a pin vice drill and bamboo strips run through a draw plate to get the correct size.
The cannons were rigged with breeching rope (0.75 mm thread) I used zip seizings for the seizing of the breeching rope. Am in the process of finishing the rigging of the cannons and will post some more pics once that is completer.
I have attached some pics showing the build from the beginning until the last stage to try and give an impression of how the build has progressed.
Dave ,,,,
