PSF
Everything posted by PSF
  1. Installed a permanent lower and upper cheek (see Figure) from Yellow wood = Amaryl
  2. It's time sets the anchors. This requires the marine rope. So I need to install on mechanism of winding marine rope (а) electric motor Here's what happened:
  3. As always, the first test, and then ... The following photos are only the test These parts are not installed on the adhesive
  4. installation hobnail into the side of the ship hobnail from brass wire 1. marking zones position for a hobnail from brass wire 2.made the tool installation for the hobnail from brass wire 3. To complete the installation the hobnail from brass wire has spent 2 weeks 3 hours per day
  5. Certainly hard! With the help of Bor-machine (see photo) and burs for jewelers Of course, in one place of part broken. I glued it on the glue is already in place but if done carefully and cautiously, then happen without failure
  6. windows are painted and installed window frames are made ​​of yellow wood
  7. установлены перила верхнего балкона
  8. window from Kit improved window then will be painted in gold paint
  9. The crossbar window is made of yellow wood. Glass from plastic from a floppy disk. The transom stern of blackened wood - hornbeam
  10. Continued production of the end mill strips rubbing strake from blackened hornbeam
  11. Two evenings cooking the end mills. Turned out one of the three necessary. The end mills produced relief strips rubbing strake
  12. made a mistake, put away a lot of area balcony: the perimeter of the balcony <> perimeter railing way to fix on the photo
  13. painted in black hinges of the rudder ship with a solution: chemical solution 25% ammonia (ammonia), 100 g / l to 1 l Copper carbonate (CuCO3) 40-200 g / l Instructions: http://shipmodeling.ru/content/tooling/брассблакинг2 Additional Information: http://shipmodeling.ru/phpbb/viewtopic.php?f=11&t=1599&p=161934 # p161934 parts have been cleaned with a hot solution of citric acid parts have been cleaned with a hot solution of citric acid
  14. hinges of the rudder ship sharpening on the milling machine Proxxon M70, brass rod welded to a silver solder with a gas torch
  15. another variant of the manufacture of hinges is the pen of a ship's steering wheel method of manufacture http://forum.modelsworld.ru/topic207.html
