Bripea
Posts posted by Bripea
I used my wife's fabric steamer. I traced the nozzle end and made a cut out in plywood thick enough for the nozzle to be almost completely embedded, then another piece of play with rectangular cut out so only 3 of the nozzles actually would supply steam. I put these together and build a plywood box around it. The lid fits on top so that there is easy access to laying the strips onto the movable coat hanger wire racks inside. There are 3 vent holes at the back to allow the steam to pass through. Careful when opening the lid and steaming your fingers, maybe long tweezers to pull your strips out and start bending. I usually use the kitchen kettle but it clicks off when boil is reached. I haven't tried this yet since I caught a finger end in my table saw to my dexterity in bending is much reduced until the stitches are out (stupid me).
- thibaultron, cog, Walter Biles and 1 other
4
PLANKING STEAM TANK
in Building, Framing, Planking and plating a ships hull and deck
I notice the lid did distort a little. I tried steaming a number of planks at one time, which did soften them all, but noticed that if I started bending a plank then put it back in to steam some more it would have memory and go more or less back to its original shape i.e. almost flat. Therefore I only had partial success. I did, in fact start poking the plank in at the steam end to re-heat while shaping it, so not much better than the simple pot with handle removed idea posted after my post. What worked best is using the fabric steamer head alone to steam and start shaping the plank, then steaming more after initially attaching the bow end to the hull. This allows me to get it closer to the bend and twist needed to run the length of the hull. I'm also going to try just two racks in the steamer and a weight in the middle to give some initial bend.
