Johnny Mike
Everything posted by Johnny Mike
  1. To E Sounds like you have me beat with bad luck. I agree the brain is rebuilding but it is slow and you have to force it to work. I continue to improve even after three years. I plan to continue to build ships and encourage you to do so the same.
  2. Thanks everyone. I like to see what others are using and especially the tools they use and the layout. Very informative.
  3. Thanks I will check it out. When I turned 62 I felt like retiring because I and enough and was not happy in my job. I realized it was not the work but the work environment. One day I quit the job I had working in the same industry my entire life. I did not know what was next because I really did not have a plan. To make a long story short an acquaintance said ' lets build machinery together'. I thought what the heck. That was 15 years ago and we have built over 50 unique steel tube scarfing machines that improve operator safety. We have had a great time. The last 15 years have been the best in my life. I have created a steady income stream for my wife and I and truly secured out future. I guess my point is I agree with you. And you never know. My life sure did not go as I thought it would.
  4. Thanks so much. I really like sharing ideas. keep them coming. I have some new ideas to think about already.
  5. Maybe I am just missing something but I am interest in other builders work areas. I can get many tips just looking at others work areas. I am a solitary builder and don't belong to any associations to share information. The only contact about my hobby of model ship building is from Model Ship World and an occasional vendor or web search. Which is fine with me. I know there is a spot to put specific information on tools and equipment. I would like to see a location to look at other builders work area. I am not interested in discussions about the best tools and what you should have but simple one or two pictures of the builders bench or work areas. No description needs to accompany the pictures just let me explore the pictures easily and quickly without searching all over for this basic information. I have found I can pick up many hidden gems buy just studying others. .
  6. Not sure if it is right for your application but I build 16 and 17 century tall ships so almost everything is wood. I use Creality Wood filament PLA 1.75 because it is 30% wood. All the parts were printed on a very inexpensive Creality K1 printer. This is off the printer with no cleanup, sanding or touchup. The second picture is right off the printer so need to be cleaned up but I will leave the vertical lines in because has the look of sawed rough wood.
  7. I agree with "W". I have had so much frustration with super glue I gave up a couple of times but finely hit on the same as "W". The tip is key but also the screw on cap. You can leave the tip on or unscrew and cap and the screw on cap seems to seal better than push on caps and does not get stuck on the bottle. I imagine Gorilla glue is good. I accidently ordered from Amazon and got this industrial glue produced in China but it is good stuff too and seems to last unchanged in viscosity and dry time and it is 2 oz.
  8. I had a good desk set up I did not want to change. So I just added an adjustable computer stand. It sits right on top my existing desk. Some of the best money I ever spent on a hobby.
  9. I am exactly the same. I practice writing [or printing] daily and it is getting better even after 3 years. Very slowly but noticeable. When I started out my brain could not even figure out how to hold a pencil. Writing is probably the most difficult daily function and I write for practice even though I use the keyboard for almost everything. I can tell you it gets better the more you do.
  10. Alan and Mike Thanks for responding. My situation is very similar although I was fortunate enough not to have a stroke when I woke up from the operation nothing on the right side of my body worked. Of coarse I am right handed. I work on writing a lot and getting better. That simple thing pushes me to small improvements. Who ever thought writing would require so much brain activity.
  11. Thanks for your response. I understand and I have to adapt to my situation. The response is very reaffirming for me to keep trying. As mentioned recovery is slow but in my case continues and even after 3 years I can see very slow but continued improvement. I do force myself to keep trying build what is hard because I know you have to force yourself or you will not improve. I to, have found I use a lot less superglue and have to clamp pieces I would have held before. Thanks, I think the encouragement you have given me is the most important thing.
  12. I have been building wooden ship models for a long time. I recently had brain tumor removed and although I am OK lost the fine touch in my hand to do quantity workmanship. Can any one give me pointers on how to improve.
  13. I have had a standard office desk I have been using for years. Recently I added an adjustable height computer stand. It is very helpful because it is compact and easy to adjust the working height. Good up high for details like assembling grating and low for general work. Inexpensive also. I don't use the top section here but moved it to another location for my mini sanders.
  14. As mentioned there are many types of CAD programs. I started with auto cad LT but of coarse it is only 2D and you will need 3D for printing. For a while I used 2D and had a friend convert them to 3D but this does require some time to do because they have to redraw the piece. I am using Solid Works now. Not cheap but I like it because it is common as used everywhere. And will communicate easily with most all formats. These may not be the cheapest but they are professional grade and produce electronic files easily read by most software and printers. You will be best if you make sure what ever software you use can produce a drawing in STL format. Or something that a printer can read. I can design and draw a part in STL and down load it to my printer and print with no issues. Printed parts shown using PLA wood.
  15. I am building the Batavia 1628. And just printed some parts the first time for me 3D printing. I am amazed at how good the parts came out. Some parts requiring high detail I decided to try what Creality calls wood. The color and texture are exactly like wood. The surface is just slightly rough and a perfect match to wood parts. One part I printed was the gun doors. I drew them to scale and added small lines to simulate the joint between boards. The realist look is great. I also printed the belaying pin racks with the holes to hold the pins and they are perfect. This is my first try at 3D printing but I could not be happier. It is a great addition to building tools.
  16. Thanks That's is what I thought. I have used Autocad for many years and did not want to learn Solidworks or Inventor
  17. I know and use 2D Autocad almost daily and just started 3D printing parts for my Batavia build. I want to be able to supply an STL file to my printer. Is there a simple program to convert my 2D to 3D
  18. I started building the railing on the Batavia a stick at a time and finding it very difficult to get the pieces cut to the length, the correct angle with the deck and equally spaced. And I just was not happy with the glue joints I had on all these small individual pieces, up to 13 per section. Plus it took forever to do each assembly. I tried to build the assembly then fasted to the deck and build each rail piece by piece on the ship. Then I thought if I drew the rail assembly on Auto cad I could get all the angles, lengths and spacing exactly correct and print it 1/1 scale. I could cut it out check the layout by placing it on the deck for accuracy. This worked great I could check out everything about the fit and look of the railing complete. Then I could use the cutout to lay the parts on before gluing them together on the template. This worked also and I had an exact rail assembly I could mount in place. I have use of a 3D printer and thought why not print out each assembly using my drawing. I had found some newer print material that looked and felt like wood and printed them out. They look exactly like wood with perfect joints. 20250517_101404.pdf
  19. Thanks for the comments, I guess. Seems the thread has taken a direction of its own. My intent was to give armature builders, like myself, an idea to make a fairly simple task out of a tedious task that in my opinion looks pretty good. That's all.
  20. I had the same thing happen years ago building the US Dallas. I am sure it was because I planned one side more than the other before I noticed it. I did a lot of trying to straighten it without much luck. I eventually decided to soak a towel in water and wrap the whole hull and firmly clamp the bow and stern in c-clamps and gently over torqued the hull slightly. I did not have all the planking on so I could twist the hull slightly. I kept the towel damp for a week. It worked and I still have the ship today. If you look very close you can see a very slight twist but now much.
  21. I found an easy way to build wood latter's and steps is to take pre cut wood grating and glue it in the configuration of the size you want then cut it into individual latter's, sand edges and cut to length.
  22. Sorry I did not post a picture I was on an unfamiliar tablet at the time Here is a picture. I started the planking but quickly found out I can not continue this way without twisting the planks, and doing this to fit seems almost impossible. I have looked at laying the planks on an angle but this doesn't seem to work either.
  23. I am building the Batavia and can not figure out to 9lank the two areas that would be the captain s quarters at the rear of the ship.
  24. Just go to 'mini clamps' on Amazon and you will see anything you need.
