Srodbro
Status Updates posted by Srodbro
Regarding your response to my comments about the advantages of solid hull vs. POF or POB: (not wanting to further hi jack MTaylor’s log)
Yeah ... remarking station lines frequently is a pain, that’s for sure. However on the flip side, it ain’t hard to establish a waterline! But one spends much more time referencing station lines, it is true.
Jim:
I just today noticed your post in jablackwell’s Syren build log on 11/29/2017 and your use of Redheart for the ceiling on your build. I have been doing the same on my Lawrence (aka, Niagara with modifications).
I used Redheart for the bulwarks ceiling, and Osage orange for bulwarks exterior planking.
So, a couple questions for you ...
I read that the Redheart will fade over time to dull grayish-red, so lightly coated with red stain. Did you do anything to preserve the color?
both of these woods were very hard and brittle. The first strake below the gunports on the exterior is Redheart and no matter how long I soaked it, the planks snapped when bending. I finally had to plane the plank down to nearly 1/32” to get it to bend. Did you have similar issues?
I am also using Redheart for carronade carriages.
Thanks.
I steam bend with no issues. I tried the soaking routine and had the same results as you. I coated mine with a satin poly after installation. OMG what a color pop. You can also use Tung oil. I also used Redheart on my Rattlesnake ceiling and loved it. Another wood I use is Yellow Cedar for decks. A lot of people use Holly because they say it resembles a hollystoned deck but I think it is just to white. The cedar is the perfect shade. Not brown not white. I thought about doing the carriages with the Redheart but I like the contrast between the Redheart ceilin, Cedar Deck, black fittings and flat red carriages. That is a very good looking Carronade. Like the pop of brass.Your Lawrence is going to be stunning when complete. Here is a photo of where I am now. I build from stern forward and try to complete everything in a section prior to moving on.
Good looking build you have there. I almost like your flat red gun carriages slightly contrasting with the deep red Redheart more than my scheme (almost).
I like your light colored deck. Mine will be a bit more subdued, using mahogany with a light gray stain and satin poly finish. I intend to make the companion-way, grates, and fife rails of walnut. But, with this color scheme based on natural wood colors, I’m not yet sure what I’ll do with finishing the spars and tops.
