Brian Jackson
338 profile views
  1. As I have not had any replies I can only assume that there are no drawings that I can use However it occurs to me that photographs of the slabs, with the part numbers visible, will be enough for me to use. Is anyone able to help with this? Thank you. Brian Jackson
  2. As part of my retirement projects I have received a model kit of the Scottish Maid made by Artesania Latina in Spain. When I came to start assembly I found that the wooden slabs that contain the parts do not have numbers against the parts, so I cannot relate the parts to the assembly instructions, which on some of the slabs is not a problem as they are unique. However on the hull assembly the parts are very similar and if they are not assembled in the correct order the model will never be right. Does anyone have drawings of the slabs with numbers so that I can copy the part numbers to the woos and start the assembly? Thank you
