Eric S.
Members-
Everything posted by Eric S.
Shortly after my last post I broke one of the floor boards while sanding and couldn’t get the rudder/ gudgeon/ pintles to work and got frustrated and set the model aside for a while. Built an rc car kit and a couple plastic planes and came back to this earlier this summer. Crafted a new floorboard and soldered the rudder assembly together and am back on track.
I broke the mast step and noticed others have had this happen as well. I built a new one from a solid piece of scrap wood and have a couple of questions. Should I err on having the mast hole slightly too large or too small? I don’t seem to have a drill bit exactly the right size. The step sits inclining upwards - should the drilled hole also have a slight tilt so the mast is straight up and down? As others have noted, both mast step pieces have holes. Is a solid bottom piece needed or does setting the mast on the hull work? Seems like the extra distance to the hull would stabilize the setup a bit. Thanks for any suggestions.
Replying to Lessard from above, I found this project after a couple of missteps. I tried building a couple of kits, the 18th century longboat and the Phantom NY pilot boat, and they were beyond my skills. I ended up throwing them out . But I was still interested in building a wooden model and I noticed the Grand Banks Dory and the progression of kits in a Model Shipways advertisement and decided to give it another try. Really happy I did so and am now on to the Norwegian Sailing Pram. The Dory is a very nice intro kit.
- 12 replies
- Lowell Grand Banks Dory
- Model Shipways
I seem to have stopped taking pictures at this point, but did get a few shots of the final product. On to the Norwegian Sailing Pram. Thanks to Model Shipways for a fun project that has me excited for the next model in the series.
- 12 replies
- Model Shipways
There were a number of times where I felt like the planks weren’t lining up and I couldn’t figure out a way to tie it all together, but I stuck to it and eventually got the boat planked up.
- 12 replies
- Model Shipways
I felt frustrated to not be able to line everything up but found that a bit of patience and some sanding takes the imperfections out.
- 12 replies
- Model Shipways
The instructions are clear and it wasn’t long before I found myself getting ready to set my first plank
- 12 replies
- Model Shipways
Hi – I’m Eric and this is my first post to the site. I’m primarily a plastic modeler – boats, cars, armor, airplanes – but have long had an interest in wooden boats/ships. I fell prey to buying a couple of kits that were way beyond my abilities before deciding on a kit that was more appropriate and bought the Dory. I meant to create a thread while building the model but only took pictures and did not post any updates. I got so much help from the completed builds, however, that I felt that I wanted to share some of the pictures of my Dory build.
- 12 replies
- Model Shipways
