Chris.
Everything posted by Chris.
  1. It will be the case of all which will support upper decks in order to enforce the structure before out planking
  2. The ninth frame, 56% is done (not glued) : After each adding of wooden cut, I verify all curves and alignments to be safe
  3. Now, after the eighth frame, the shape moves slowly near the quarterdeck, 50% is done :
  4. Could an administrator move this interessant discussion into appropriated topic : Charles Galley by Allan ? Thanks, Christian
  5. Hi Bruce, I fix my bulwarks with two opposed half notches (male and female), one down the mould, and other up the keel Regards, Christian
  6. i have a dictionnary of marine vocabulary of 18th century... but you have to open it for use... Moby Dick's monograph exists also at scale 1/36 = length 2.20 m 😘
  7. The two solutions without sinking gammonings : I suppose that the piece 204 don't arrive at height of upper volute (hances and standard knee are different pieces)
  8. Here I show you a redraw of plan using your recommendation, and water line cheated down 1/8" (around 3-4 mm) : The ropes will be out of water, but with the decorative element hidden by gamonning, without inconvenient, it's not an immortal masterpiece of Art 😋
  9. The first rail is almost finished, closer to a work of sculpture than of engraving : Then, like pancakes, turn it, and start again the same work of cook, without burn out 😘
  10. I had inform you that I decided to follow my first idea about gammoning of S-Philippe, I cannot follow the sinking ropes... 😘
  11. @Hubac's Historian I received a notification of a message titled "test" send by you, but I found any message on site ? What a curious mystery ! 😋
  12. I have the "choice" between an historic "probability of truth", and another approach, more "creative" J-C Lemineur wrote to me that my proposition had existed, but later, then it would be an anachronism, that's also your point of view... I shall take a moment of reflection before a definitive decision 😘
