Everything posted by Chris.
After frenchies, I've to reduce size of my sheaves : too large... To remake is also to make... 😀
The heater went to install the electric radiators, size seems good, I'm winter ready... 😘 :
A little quiz : There is a great error on one of the two pics of my prevent message Could you find it ? 😀
I made two pics of sails, after Madrid Museum (up) and Pastore (down) : only difference I've found, a little horizontal mast behind stern
Two pics of bottom block : Wheels size 1/48 = 5 x 1.6 mm, at real size 1/1 = 24 x 8 cm (rope about 1.5 mm)
Thanks Louie da fly 😀 A french expert told me that the lower block was around 1480 an archaic block articulated on a cringle (Halyard knights arrive later) I would add that a large 600 kg antenna requires four reals, even using a capstan, otherwise, hoisting would be difficult Three reals is good for the misain mast, not for the main mast Finally, the pulley followed the inclination of the mast, (8° on the Niña), that is the reason why it was articulated Later, the halyard knights followed the same angle as the mast. (Otherwise, they would break quickly) I think that such a disposition prevented the problem of twisting rope you met on your referenced model Regards, Christian
