woodartist
Status Replies posted by woodartist
When you were installing your waterways, after you had beveled the inside edge to meet the planking, did you have to clamp in the waterway as you cut the bevel for the side that backed up to the bulkhead? Did you do any wetting of the waterway before you forced it next to the bulkhead?
Thanks for your build log it has been of great assistance on this journey.
Before I make a fatal mistake, I need to better understand the relationship between the Bearding line and the rabbit. Am I correct that the Bearding line is the merge point between the Keel and the lowest plank on the hull? Is the goal to reduce the thickness of the keel at the bearding line by the thickness of a plank so that the last plank's bottom edge is flush with the keel?
Is the rabbit the rounding of the bottom edge of the keel, so that there are no sharp edges? To do that would you find and mark the bottom center line and then gently round each side of the keel to the center line?
Also, I am still concerned about the difference between bulkhead from the pattern plans as referenced in my last post.
Chuck
I signed up/paid to get plans for Winnie. Considering building the Winnie. Read a lot of the build logs. Confused by the scale postings on build logs. Some list 1/4 others list 1:48. Are these the same build or is there truly 2 different scales? Without completely reading every page of build logs have there been any issues with the cherry? I read one log where the builder started in cherry but later started over again in boxwood. Thanks
