Geam
Status Updates posted by Geam
Having made the semi-scale interior cabin details, I decided that the hatches on the 2 companionways as well as the foreward deck hatch should be functional. ie. the hatch can be opened to reveal the steps and a narrow view into the hull below.
To achieve this, I have installed a small brass hinge on each hatch. Each hinge will locate into a hinge 'beam' -as used on the present full size CA RS1. The small (non-operating) plastic hinges supplied in the kit will be used, but cut in two so that they will not prevent the hatch from being lifted up.
It's this kind of sidetracking that results in my rather long build times. I get some crazy detail idea then take ages to work out the logistics of it, and ages again to produce it! After all that thinking, my brain cell needs a rest before getting on with the build!'
George
Plodding along slowly with the Colin Archer RS1. The hope to launch at Easter has been abandoned. The skylight and other deck structures are under construction. Not sure if the planking on top of skylight and companionways should be stained teak or kept natural. I intend to keep the deck planking 'natural' with no stain -just oil and varnish. Some of the wood in my particular kit is quite dark and I stained it teak thinking that all the rest would be stained teak anyway. Post a few progress photos.
George
Glued on the gunnels and cut the 32 railing posts and dry-fitted them to the gunnels. Deck/hull joint has been filled with Tamiya white putty ready for sanding. Glued the main hatch deck onto the frame.
Not sure about the best sequence for the next steps but I think I'll paint the red hull hull stripe and then stain the gunnells in teak. Made a helmsmann's seat and instrument panel for the steering well this afternoon.
Happy new year to all,
Work -or play- on the Colin Archer has been stopped by the production of an Xmas train set under the tree. All that is now packed away and the CA is in focus again. The R/C gear has been installed and mostly obscured beneath seating and inside lockers. A number of extra hatches (6?) had to be opened up on the deck to give access to main R/C components. It will be interesting to see if I can make all of these watertight later. The ready cut deck sheet will be epoxied onto the hull during the next week or so. Before that, the rudder servo has to be connected to the rudder via a pushrod through the hull. Also the two winch drums need to be loaded with sheets and led to the main boom and to the foresail. The foresail sheet needs to be led through the deck via sheet guides. Sounds like I know what I'm doing, but I don't; I just know what has to be done😅
As usual, recent progress has been slow. More interior details have been completed and the R/C installation will start soon -ish. A lot of wiring to be threaded though the outer bulkheads and under the seating etc. Doing some head-scratching over the position of switches and fuse. A bit crowded due to trying to keep the R/C gear hidden from view, but accessable enough for maintenance.
The long-awaited compass arrived in the post at last. It will hardly been noticeable through the open deck hatch. The importance of this detail grew out of all proportion after I incorporated the porthole in the steering well. Anyway it's there now. The open porthole surround is a bit too big but again, will hardly be visible later on. The real one is shown...sideways!
Trying some test-assembly of interior components. The aft cabin bulkhead with an in-locker navigation station is in place. The bulkhead is removeable to give access to the 2 servos behind. The pigeon-hole/shelf in the centre will house the compass which can be viewed by the helmsman through a large porthole in the steering well. The well has been given higher sides than shown in the plan to help keep water out when sailing.
The door to the heads has been fitted with a (slightly kinky) frosted, green-glazed, porthole!
George
Progressing slowly with the different components of the interior. Now rounding the last 'corner'. Not too happy with the home-made hinges on the stbd locker door. Only one or two of the locker doors actually need working hinges. I have found some miniature brass doll's-house hinges in the UK -which are now in the post to Norway.
The workshop area, aft to port, and the adjacent 'heads' are also in progress. The opening for the compass-viewing porthole in the steering well has been drilled.
George
Bulkhead between saloon and what is termed as 'the hallway' has been installed. Don't know what else to call this area where the companionway steps will be. The 'hall' will enclose an aft sea berth to stbd, heads to port, engine, workbench to port, and a chart table on top of the engine cover. There is also a navigation area with a radar screen and GPS built into a locker and a rather large compass which can be viewed through a pothole from the steering well.
Slow progress recently due to unusually good weather here in S-W Norway. Have constructed some interior detail which will eventually be painted in the green colour used in the present Colin Archer RS1 afloat in Norway as shown in the lower photo. Saloon deck will be planked later in oak-stained pinewood.
George
Apropriate beams/stringers have been cut away and a mainsail control winch has been fitted abeam the cockpit/steering well. The winch is a 4-turn Krick unit nr. 1004MG. The mainsheet will run via a brass guide tube, through the side of the well, up to a ring on the mizzen mast and to the end of the main boom. The winch drum will be fitted later in the build!
George
The cross beams and stringers are in place now. Some need to be cut away to give access to the hull internals. Deck shown, loosely placed on hull. R/C gear locations to be planned next. Then I'll have a good think about whether or not to try to build an interior around the R/C installtions. It will take some time to achieve I fear.
I have made some small adjustments to the genoa sheet runs above deck. A new, additional sheet block has been added further forward in an attempt to give more downards pull at the genoa clew and thereby tighten the genoa leech a bit. Under sail, the top section of the genoa often has too much twist and the wind spills out and does not provide thrust -just flutter!
The YouTube videos can be seen by writing "Model Fisher 34 motorsailer 1/12th scale".
The Billing Boats Colin Archer RS1 is now up from the cellar store and the build is underway....but at a slow speed-ahead.
George
