Interesting to see the work on the Princess Royal! I too am about to finally get started on this same model. For some reason, I am missing the original template sheet? I have, however, a Xerox copy but I do not believe it to be correct in dimensions? I wonder if, perhaps, you could send me the dimensions of the "trestle jig" pattern off of the original template sheet? With that I should be able to adjust what I have to create the correct size.
What I have shows the top template (marked off rectangle with the hole patterns) to be about 9 1/2" x 1 1/2"...no idea really if that is correct? Since the directions call for a block of wood about 10" x 2 1/2" maybe what I have is pretty close? Thank you!
Randy S.
