        DmitriyOG
Members-
                Posts30
Everything posted by DmitriyOG
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	Guys give me some inputs and ideas please
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	So Im debating still on how to proceed with these cannons. These are the types Iam planning to use for lower deck. As you can see the middle fat cannon in the below pic can only go in by it self and they do look good and big. 2 on the left can be turned in to a 3 pair. 2nd from the right is the 4 multi canon set up, as a single cannon it looks pretty tiny in the pic below. The first from right probably best used as solo as well. Keeping in mind, pirate ghost ship set up cannons should be a little interesting thats why Im thinking to put some multi cannons
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	@Jeff T hey what do you think of such cannons here. Im thinking to use a few multi set ups. Just to make it look more scarier
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	As promised some updates. For now gold glitters. All the gunports in and working. Cannons and chains are coming next for the lower deck.
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	Hey every one! Thank you for checking my build out! More modifications have been done. Pics are incoming later tonight
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	Gun ports will be going in next along with cannons.
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	All the gun port chain entry points r done. And primed with gold. Also anchor chain hole decor complete primed in gold as well
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	Well I havent had a chance to get to it yet. Will keep you guys posted. Coming soon in the next couple of weeks mb even this sunday, we shall see if I have time.
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	I have been debating with that. Will be experementing first to see what works better. This weekend should be some progress thou.
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	Originaly I wanted only 1 chain attached to the lids. Since they were metal and I had to drill them out, corner holes were best option
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	It will be very time consuming per canon. I need a rope/chain entry in to the hull. Driling a hole wont suffice. I have started on some decor-square pices to mount to run the chain thru. Not much luck yet on production. I will need around 46 entry points. Pieces I am trying to make arpund 1 mm thick Very hard to cut identical thikness. Almost imposible to sand after as they are tiny
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	Very nice! Ver6 close to what I had in mind. If you look above in to my gun port lids, u will see I have attached 2 rings. So im thinking top part will function like u have in ur discription. Only it will be 2 chains going above in to the hull. And hooked up to the cannon/cariage and 2 lines coming ouy from the port and hooked back up to the gun port lid. That way closing or opening it should pull the canon in the right direction
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	Yes, I have looked at that ship when I was doing my research. Havent had much progress. Working on a gun port system. Some how have to make them open and close and move the canon at the same time
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	Trying to create some windows and doors decorations here. Let me know what you guys think. Would they look good or not
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
	More coming! Already made a few . Need some help on some gun port decisions. Will post some pics soon
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
- 41 replies
		- Spanish Galleon
- Flying Dutchman
					(and 3 more)
