Avi
  1. I did. Like all other paints. I am glad it is helpful. I wish I had time to do more now, but hopefully end of summer will give me the opportunity.
  2. My apologies to everyone for no updates in several months. We have been going through home renovations and preparing for a move, which has sucked up every bit of available time (and then some). I hope to get back to building the hatches and coamings by end of the summer and then moving ahead with the gundeck. I rather do miss it!
  3. Oh, now that is an interesting idea. I did a search on their page for "gratings", got this. I assume one of the first few?
  4. Oh even better! I can use a whole piece of paper and glue the coaming pieces to it. Then what it all dries, just cut out the middle.
  5. Those are two good ideas. I thought about a spare piece of plank across the corners. Those are pretty thin, but I think still thick enough that they would make it not flush to the deck. Paper, however, would be great. For those hatches that have gratings, I can make it a little wider, so it also would provide corner support for the gratings. Another alternative is cross supports. I can use spare plank and literally cut across the middle to middle, for those that have gratings. But I like the corner idea. I can do it for all of them. I don’t think I bought wood coloured paint. The blackening is a good idea. So what did you do in the end? Just leave it shiny brass?
  6. Might as well make the coamings in the meantime. Or try. 😁 The grating is ¾” square, the coaming wood is 1/16”, so the whole thing is 7/8” square. I cut strips 7/8” long, then used the mitre box to cut 45’ angle on each end, and sanded where necessary. the question now is how to connect them. The wood is too narrow for a pin - it probably would split it - so glue is the usual fallback. Unfortunately, the tiny surface of the attachment angles means it doesn’t have a lot to hold onto, and the long relative length of the attached pieces puts too much torque. I suspect, although am unsure, that if I could do all four pieces at once, they would support each other, but I don’t quite know how I would do that. I might try painting the sides white and varnishing the top, and then gluing them together and to the deck. The deck should provide plenty of surface.
  7. As far as I can tell, 3 of the gratings are intended for the gundeck, 3 for the spardeck, plus the big triangle shaped one for just behind the bowsprit. I’ll attach a picture of them on the deck but not attached (and no coamings yet; that’s next). The painting guide says, “gundeck hatch coamings - white - sides white; tops natural wood.” That’s easy enough once I construct them. But then, “wood gratings - natural wood - valspar varnish.” Needless to say, the gratings are not wood, but are photo etched brass. so do I leave them brass? Paint them something that looks like it might be wood?
  8. Aha! I’d missed the sheet of PE parts when I searched earlier. I’d forgotten that they were stored in a different container. I imagine if I’d been looking for something obviously larger, like the transom, I would have realized immediately there was somewhere I didn’t look. Thanks Kurt.
  9. That’s really helpful, thank you. I didn’t see anything like that, but I’ll do another detailed search later today.
  10. Hi Kurt. That explanation helped. I see what you’re referring to now in your post. I’m not sure I know what the PE gratings are. Are they squares, ready to place? Those strips in the picture I posted, that need to be combined? BJ has two different wooden gratings on their website, this and this. But that’s clearly not what’s in the kit.
  11. There is some description of the gratings and pictures from @KurtH here post #5. Kurt, I didn’t quite understand what the “brass ones with holes are” and what you ordered of walnut?
  12. I messaged privately but not publicly. And I need to comment here so I get posting notifications. Welcome to our club!
  13. Do you see description on a specific post there @JSGerson? I couldn’t find anything. On the other hand, the discussion about shot for the lockers will be very helpful.
  14. I cut out the hatches and drilled the holes in the planking for the masts. Some of the planking cut loose in the process, so I glued it back. For the hatches, I marked the outside, felt by tapping where it definitely was hollow on the other side, and drilled small holes in each of the four corners. That made it easier to use a keyhole saw to cut the quadrilateral shapes. It then required some fine trimming with an xacto knife. At the end, the black paint inside the hatches had gotten marked up, so I repainted parts of them. For the masts, I used progressively larger drill bits to ensure I wasn’t veering from the existing holes in the main hull, which had measured correctly. I had to look back at the supplies list to see the diameters of each mast to know what size I was targeting. They all worked out well in the end. Interestingly, despite a relatively short session, this may be the one in which I used the most tools and did the most activities in a long time: drill, keyhole saw, knife, sander, pliers, glue, paint. Usually a session is dedicated to one or two activities, like cutting and gluing, or painting, etc. Next to shape the hatch coamings. It isn’t clear from the guide if there is wood dedicated for this, or if I use spare planks. EDIT: the parts list shows W1370 1/16x1/16x24” for the gundeck hatch coming (along with lots of other things), and W1371 3/32x1/16x24” for spardeck hatch coamings. The other confusing part is the grates. There are 7 hatches on the gundeck (including the very large main hatch), and another 6 on the spardeck. The parts list shows 7 gratings supplied as part of the photo etched brass parts. Is there a plan as to which hatches should get gratings and which should not? The plans show 2 on the gundeck plus the main hatch, and 3 on the spardeck, but hard to tell if that is an actual plan. Or is this more “do what you want”? Also, what exactly are these “photo etched brass gratings”? I don’t see anything that looks like a grating. Is it the pic below?
  15. Thanks @schooner I was worried about something similar. I drilled holes into the carriages to have the option, but it didn’t inspire confidence in me. So I took a piece of spare planking, cut it to length, painted it black, glued it between the two trucks. Once on the deck you cannot see it, but it gives a large surface for glue contact. I’m hopeful that will work.
