Bartle
  1. Hello 🙂 I'm a french 3D architectural modeler from Marseille. I say Bravo ! to your 3D created & printed stem cargo winches. I started making a fine 1: 100 ship model (the ship my grandfather sailed between 1932 to 1959 as first stoker-greaser grandfather sailor biography), the mediterranean liner S.S. GOUVERNEUR GENERAL CHANZY, a 1921-1922 built for the french government and the "Générale Transatlantique French Lines Company" by Cammel Laird at the Birkenhead shipyards. I was able to find many parts of old copper fittings on eBay but I couldn't find all of the perfects decks fittings required (hard to find... a very poor fittings choices since 1970-1980 since closed scale model suppliers of their static naval model department). The 1920 windlass of my grandfther boat was a very peculiar one, nearly the same as the 1910 NOMADIC ones with a vertical steam engine on his back but certainly modified at french shipyards with an adding of two steam pipe lines on his head S.S. Gov. Gen. CHANZY peculiar vertical engine windlass. Finally I must create a 3D file to print. I searched some 1:96 steam cargo winches 1920 Liverpool cargo winch for a long time since 2014 and finally found some OO correct metal model ones in 2019 1:100 cargo steam winch but it was an expensive cost (6 items needed). On the other hand I couldn't find the 14 original S.S. Gov. Gen. CHANZY Welin quadrant davits in a 1:100 scale (except in an obscur ukrainian adress) so I model them in 3D file too, as the S.S. Gov. Gen. CHANZY deck lamps. I modeled them for a 3D print but I must find a good metal printer solution now. If you need these deck fitting models, don't hesitate to contact me. @Hicksan You said "I do wish I had access to good drawings of such gear, would love to work up some better designs." : I found in a forum an old modeler post with a cargo winch design, an original 1910-1920 fine one, perfect for a 3D STL modeling, so I repost here for sharing. Hope it help you and the community of naval modelers.
