Gct86
Everything posted by Gct86
  1. I've used metal lifeboat by kit Amati, But I'd like to cover boat with false-leather cover (i've creased a piece of paper then paint it) In your opinion is better light or dark brown color?
  2. Flag locker a little bit different than Amati's plan. Similar to Anatomy kf the ship. Now i'm gonna aged wood
  3. hello and thanks for your comments! I wanted to build a dystopian bounty, in a world where the ship had not been burned by the mutineers and held in Pitcairn Bay for a long time. so I coated the keel with copper and used the AK burnisher, quick brush strokes. the copper was stained with cyanoacrylate glue so it was easy to create a smudge effect. then I drybrush some acrylic color mixed by myself to give copper oxidation. with a drop of glue cyanoacrylate then I glued some paper tissue painted in green, black and brown to simulate algae a little, but without exaggerating! I'm glad you like it See you soon!
  4. Hello construction updates second planking copper shield hull aging
  5. First planking complete. I must sandpaper, but I hope this is a good first planking.
  6. Meantime I've completed (excluding hatches) deck planking and caulking. For my Bounty I though a "worn out" finish, post-mutiny period. So I've putty planking whith black milliput. Milliput is very hard to apply, but I like the result.
  7. For example: Here seems almost correct: Here not (must sandpaper a Little bit):
  8. Thank you. Actually I have to sandpaper a lot because there is a "belly" too big in the center of filler blocks. Using a 0,5mm strip I'm trying to understand the correct curve of hull.🤞
  9. I'm trying to make bow filling block, but I don't know if I'm right. Any advise? Thanks
  10. Thank you Dave! Many times I watch your videos on youtube! Your bounty is amazing and you channel is an inspiration. I try to learn somethings from videos and forum, but for me is very fun to think so much about problems and founding solutions myself. For example I have discarted filling block on stern. Probably I was wrong, but I want to see what happen.
  11. Amati kit has several mistake. Istruction tell me to glue a 4x4 millimeters (sorry I'm european😂) plank for keel, but other keel components and falsekeel are 5x5 🤔 I check all the joints and I hope to glue without mistakes. AOTS hms bounty helps me with some details (I can t reach perfection, but I will improve a little my model) See you soon
  12. Waiting for start, I've cutted a piece of wood of bounty deck shape to bending planks. Amati have a similar tool in stock. It should work
  13. I ve painted flags whit tissue acrilic color on both side with small brush and mask tape.
