ChiefCarr
Posts posted by ChiefCarr
Hi everyone,
I planked my first model, The Terror. I used rubber cement to attach the second wood, the sapele exterior. I want to coat with something to make the wood last longer because I'm afraid the rubber cement will fail after a while. I thought about painting over the top with a watered down wood glue "paint" so it may soak in a little and attach adjacent planks together. What has your experience been? Will the rubber cement be sufficient? Short of a resin/fiberglass coat to really re-enforce my work what do you recommend? I appreciate all your help and advice!
Thank you all!
Planking glues
in Building, Framing, Planking and plating a ships hull and deck
I was thinking about this as the best solution. All the pieces will fit well, and I'll be able to glue them in the same spot they're in now. I tried a test of painting carpenters glue over the top to see if it would bond the edges and it seems to have done so. I really appreciate the help. I'll post progress and see what works! Thanks to everyone!
