About Old N Salty
- Birthday 07/31/1961
Gender
Springville, Indiana
Interests
U.S. Military History, Painting, Drawing, Woodworking, Model Making.
Overworked724 reacted to a post in a topic:
US Brig Syren by Argaen Lok (aka Scott Larkins) - Model Shipways - Scale 1:64
Lowell Grand Banks Dory by LoydB - Model Shipways - 1:24 - First Build
LoydB reacted to a post in a topic:
LoydB, the long part you have circled on top looks like it might be one of the riser supports that go under the seats. The small ones i don't see. You may want to refer to some of the other members build logs or try sending the pic to Model Shipways they have fantastic customer support.
- 45 replies
- Dory
- Lowell Grand Banks Dory
(and 3 more)
palmerit reacted to a post in a topic:
Chesapeake Bay Crabbing Skiff by palmerit - FINISHED - Midwest Products - 1:20
She's beautiful indeed! I love the way you made the base. Simple with beautiful lines and not overly done to distract from the skiff itself. Congrats..
- 38 replies
- crabbing skiff
- Chesapeake Bay crabbing skiff
- (and 2 more)
It's amazing how using a smaller rope and thimble changes the total looks of that block! That Midwest kit is really a nice little kit!! I believe I might have to get one for myself.
- 38 replies
- crabbing skiff
- (and 2 more)
I wish I had a dime for every time I got frustrated over something I thought was messed up or not right with one of my builds! For what it's worth, I've built a few kits and there always seems to be something wrong with measurements on the plans somewhere.. I'm not saying that is the case with your plans but you my want to take a look at some of the build logs of other builders to see if they have had the same problem. What you might do is measure the height of the gun port openings from the top of the deck planking to the top of the port opening to see if it matches what is on the plan. As long as your gun barrels line up correctly in the gun ports where they are supposed to, then it will be a cinch for you to thin down the waterways. Just trace around the thicker ones with thinner stock and cut them out and fit them in. They will look just fine. Hope this helps.
My only Billing kit was the Bluenose II bought about 4-5 years ago. I got it on sale from Model Shipways for $36.00. I recall the lack of instructions and the kit even lacked the two props that the Bluenose II has.
- 10 replies
- hull
- color schemes
(and 4 more)
Forgot to say that I believe mahogany would be beautiful. And if you paint the upper top side of the hull black, you have to put the other white trim on it. Bye the way, is this your first Billings model?
- 10 replies
- hull
- color schemes
(and 4 more)
Hi AldZtt, basswood is what I used to plank my solid hull Golden Hind. It was leftover I had from another build and I knew I would be painting over it. I used plain wood glue and straight pins to hold the planks when needed on extremely curved areas. Afterwards brushed a little water on the pin holes and they disappeared, or pressed the hole with some fine saw dust from an unused piece of veneer. I hope all is well in Italy. It's such beautiful county and makers of great wine and ship models!
- 10 replies
- hull
- color schemes
(and 4 more)
Western Red Cedar, Mahogany, and Basswood I hear are good choices for hull veneers. I just used veneer to plank a solid hull Golden Hind and it turned out beautifully! I did paint the hull afterwards but I wanted the plank lines to show threw the paint. Just making sure that your hull is perfectly smooth and correct prior to applying the veneer because after you apply it, you can not make corrections to imperfections in the hull.
- 10 replies
- hull
- color schemes
(and 4 more)
BenD reacted to a post in a topic:
Material for small-scale oars
mtaylor reacted to a post in a topic:
I know this my br a late add on to the topic and I know that the scale of the oars being discussed is a bit smaller than what I am making, but I used the wood from popsicle sticks to build the oars for the small boats on Brig Niagra that I am building as the Basswood was just too fragile. Most wood in popsicle sticks is made from Birchwood which is much stronger. Any smaller and I would agree with Toolmaker that brass would be the best material to go with.
