T. Alex
  1. Still stringing the upper ratlines. To get a break from that task I built the top, topgallant and royal yards. They're just sitting in place temporarily of course. Still a lot of work to be done before they're added.
  2. I came across an older pic of the Captain's quarters before I added it. I sanded off the moulded paneling from the walls and made new paneling from strips of styrene. I can't remember why I did that now but I must of had a reason...haha.
  3. To get a break from doing ratlines I add lashing to the studding booms.
  4. Still doing ratlines on the upper masts. A time consuming tedious job as y'all know. The pic is of the lower foremast with spar pole and one run of ratline. As I mentioned previously I am holding off on the lower ratlines till I have some of the running rigging finished. I want to get the uppers done before I add the yards.
  5. Thanks Todd. The moulded wood grain looked to pronounced, so I sanded it smooth. (I'm sanded the grain down on every part that has it as well). Once painted I ran a piece of worn out 320 grit sandpaper over it.
  6. Thanks Robert. The kit has many shortcomings but it does have the potential to build into a pretty nice representation of the ship. So much more could be done than I'm doing. As an example (It's to late at this stage) I'm really wishing I would have fully rigged the carronades at least.
  7. Uh oh. Wife said captain Hull might have scurvy...lol.
  8. Airbrushing the Model Monkey 3D printed carronades. I used these for all 24 ports.
  9. A bit of added detail for the kit's charlie noble.
  10. How I fixed the poorly fitting masts. The mast's rakes were way off on my kit. I made new "steps" from styrene and glued them over the moulded ones on the gun deck. Then it was a matter of tweaking the holes till I was satisfied with how the masts looked before glueing on the top deck.
  11. On my kit the decks were very poor fitting to the hull. I spent a lot of time trimming, sanding and tweaking the decks before glueing them in. As a result clamps were only needed amid ship. I was happy with that.
  12. While doing a bit of research I read that there's good argument Constitution not having hinged gun port lids originally. Also that the practice was to sail with the guns run out, except in adverse weather. I don't know, but that bit of info was all I needed to make the decision to eliminate the lids. I filled in the moulded notches for them. I also filled in the bridle ports.
