Phez
Everything posted by Phez
  1. The last two months have flown by with no progress being made on this project and it’ll probably be another month before I can get back to it. Not all is lost; however, as I recently completed my first scratch build with my 6 year old’s assistance. We might have gotten a little carried away with the ballast and the hull work leaves a bit to be desired, but I think she has a fighting chance in the big regatta tomorrow.
  2. It's been quite a while since my last post but I have made some progress. The garboard planks went on without too much difficulty, though I found I didn't have much room for error with the amount of overlap at either end. One was a little too far to the bow; one a little too far to the stern, but not a total deal breaker. The broad planks gave me a much harder time. Looking back, I think it's probably because there are more variables at play, especially for a novice. I didn't realize until after the glue dried that on the port side, the two planks overlapped each other much more than starboard (first photo). I managed to to scrape the glue back to the first frame on that side and reattach it in a slightly better position. There's quite a bit more excess glue now, but I think the alignment looks much better (second photo). There is a similar issue at the stern, but it's not as bad and I had some CA glue mixed into those joints so I'm going to leave it. All part of the journey I suppose and hopefully I can take what I learned here and apply it to the final planks.
  3. I didn’t have much of a chance to work on this much over the last two weeks but I’m back at it now. My repair job on the broken frame seems to be holding up and after a lot of careful sanding the last couple days I felt ready to move onto the garboard planks. Beveling the upper edges went fairly smoothly. While I had them soaking in hot water I managed to rig up some binder clips (first photo) to help hold the planks to the frame and almost act as a ledger board while I made fine adjustments and maneuvered rubber bands in place. I vaguely remember seeing that technique in a video somewhere along the line and I’m happy with how they worked out for this step. I think it will be very helpful when the planks dry out and I glue them—hopefully this weekend.
  4. I didn't post afterwards but I got the bottom attached to the frame a few days ago. I found that I may not have gotten the curvature set into the bottom as well as I could have, so there was quite a bit of space between a couple of the frames and the bottom which required some serious rubber banding. At the time, I thought I managed to get things aligned nicely, but fast forward to this evening when I took the rubber bands off and looked a little closer, I could see some of the frames were leaning a bit. Not *terrible*, but enough to be noticeable if you look closely. As much as it annoyed me, I figured there wasn’t much I could do about it so I moved on to beveling the bottom edges, frames, transom, and stem. That was going nicely for a while and I was probably about half way there when I pushed a little too hard and heard/felt a snap. After some choice words, I went to inspect the damage and found that frame 1 detached from the bottom and was also broken on both sides near where it’s attached to the cross piece. I used CA to address each side of the broken frame and it doesn’t look completely terrible. After that set, I was able to get some wood glue and CA in between the frame and bottom and tied it down liberally with rubber bands again. It seems to be grabbing for now. I’m going to let it set over night before removing the bands and getting back to the sanding operation. All in all, not my best day, but I think I recovered fairly well and should be back on track. My goal for now is to make sure I get the beveling as good as I possibly can to maximize the surface area of the frames that will be in contact with the side planks to help the structural integrity. More to come!
  5. I worked on the frames the last two nights and ran into my first issue, which led to my second issue as you might expect. First, when sanding the char off frame 4 I snapped one of the pieces clean in half. I decided to reattach it using thin CA—not really sure if that’s the best method but it seemed like a good idea at the time. The second issue I found is that I didn’t do a great job attaching that same frame to the cross piece and it was quite crooked. I cut it off and re-glued it tonight. While that was drying, I worked on setting up the other frames in the building block. 3 fit nicely—snug with no sanding needed—while one was somewhat loose. I wet the wood a bit as instructed and it fit a bit better. I’m going to let the glue on frame 4 sit overnight before adding it to the frame. From there I’ll work on cleaning up the the remaining char and beveling edges a bit, and then it’s time for planking. But first, I need to find some more rubber bands.
  6. Hi everyone. This will serve as my build log for the second model I am attempting to build, the Lowell Grand Banks Dory. It’s been almost a year since my last build and I was exited to get started. My job and moving to a new house kept me plenty busy since that project, but I finally managed to get a nice work area together to give it another shot. Since there was a little layoff since i completed that model, and based on recommendations here and elsewhere, I decided to purchase the shipwright combo so I had something easy to start with and step-up projects to follow it with. The first few steps were uneventful and I’ve really enjoyed the historical explanations and photos used in the manual. That said, the Midwest stuff certainly had many more detailed drawings. The photos used in this product are also very good, but for an amateur, I really liked the detailed drawings. Oh well, so far so good.
  7. Thanks. I still don’t love how dark the blue is but I really like how the walnut turned out.
  8. I managed to work through the last few steps over the last week and finally reached the finish line. After removing the clamps I used on the inwale step, one side was perfect while the other was a touch high. In the future I’ll have to keep a closer eye on alignment. I thought I was good but I guess I just overlooked it when clamping. I was able to sand it down a bit and it’s better, but certainly not perfect. One tip for anyone looking to build this themselves: in hindsight, I would have attached the guards before the inwales. While trying to align the inwales with the top edge of the hull, I squeezed one of the inwales at a point where there was no frame to support it and cracked it. You can see it at the bottom of the second photo. I don’t think that would have been a problem if I did these steps in reverse and I don’t see any benefit to doing them in the listed order, but perhaps I’m missing something. Other than that mishap, the last few steps were uneventful, and there we have it. My first model is in the books. Overall I’m happy with the final result and enjoyed the challenge of working at this little project immensely. I think I picked up a few tricks along the way that should help me on whatever I start next, though that may not be until the winter as we are preparing to move at the end of the summer and I don’t want to try moving something mid-build if I can help it. Plus I have a bit of work to do on my current house before we list it. But whenever the time comes, I will start a new log for sure. If you’ve made it this far, thanks for your time and I hope you found this helpful. I’m about as green as it gets, but feel free to ask any questions about the build and I’ll do my best to answer.
  9. I’m continuing to chip away at this and the finish line is definitely in sight. The seats went in fairly easily but with the center seat I realized after the glue started to grab that I probably didn’t get as much in contact with the risers as I would have liked. I basically applied the glue right along the edge of the seat whereas the contact point is probably an 1/8” in from the edge. I didn’t want to try to pop it off and damage the seat or one of the risers so I left it and added a tiny drop of thin CA into the gaps between the seat and hull. If you look closely you can see where i applied it on one side but the other came out clean so i guess I’ll call it a win. I was expecting the inwales to take some finagling to get into place and aligned properly but it was actually pretty easy. I’ll be able to get a better look when I get the clamps off, but from what I can tell at the moment, they’re right where they should be and I shouldn’t have too much excess glue to scrape. A couple more nights and we should be home free.
  10. It’s certainly been a minute since my last update. Work and some sick kids kept me away for a few weeks. To make matters worse, I dropped the model 3+ feet to the floor and dented the stem slightly, which required more sanding and repainting. The interior is still much darker than I would like but it’s better than it was and I felt I just had to move on at this point. Tonight I managed to get the floor boards down and with those in place, I feel like the blue is a little less obnoxious. Hopefully as the seats and other details get added, it will continue to soften the look. I realized after the fact that I used the wrong scrap wood for spacers (1/32 instead of 1/8) so the boards are a little tight, though looking at the end product, I’m not sure they all would have fit at 1/8” spacing.
  11. I’ve been on the road for work a bit so it’s been a little while since my last post. Painting has been going much slower than I expected for a such a small and simple model. I’m once again glad I decided to start with a beginner kit instead of trying to jump into something more complex. I opted for a white exterior and blue interior similar to the picture on the box. I’m not exactly sure why—maybe the way the shellac dried or the way I sanded it—but the white seems to be going on the exterior very thin while the blue went on much thicker. The attached picture is after one coat of white. It’s looking better after two coats and I think a couple more might do it but we’ll see. Based on my experience with the exterior, I thought the blue would go on just as thin and didn’t try to make it any lighter. It went on much thicker than the white and was very dark. I’ve been working to sand it down and cover it with several coats of white to give myself a new base and I think I’m making some progress. After the current coat dries I’m going to try to go back with a much lighter shade of blue to see how things look. I’ll post some more pictures once I get another coat or two on the interior.
  12. My last post covered my build through step 57 in the manual. I was a bit past that when I posted it, but I’m completely caught up now. I finished step 89 today and started preparing to paint the hull. I think it’s important to note a bit of a discrepancy in the order/continuity of the instructions from steps 63 to 66. If you don’t read ahead (or watch some YouTube builds—thanks boilerdan1) it looks like you should trim the chafing plank to fit from transom to stem; however, you really need it to be a bit longer to accommodate the false stem. After confirming that, I went ahead and attached the false stem first and then trimmed the chafing plank to size. Once that was done, I settled in to fair the false stem to be flush with the side planks. It was time consuming but I ended up being quite happy with the result. Building and attaching the stem cap was a bit of a challenge for me since it was my first time working with such small pieces. I managed to get it attached to the false stem with a decent alignment. The skeg went on without too much difficulty, though I realized it is leaning ever so slightly once the glue had already set up. Not too bad though. Building the rowlock blocks wasn’t too difficult—probably since it was a similar process to the stem cap. Slow and steady wins here. Building the oars took quite a while, mostly due to the amount of sanding I had to do. Not sure how else I could have attacked that part of the build, but I think they turned out pretty good. After trimming the frames and doing some final sanding, I started prepping to paint. I used spray-on shellac this afternoon and lightly sanded everything to a smooth surface this evening. I think I’m in a good spot to start painting the hull at this point. Unfortunately I’ll be out of town for work next week so I probably won’t get to it for a little while. In the mean time, I’m going to ponder what I want to do with the oars and some of the trim pieces that they suggest just sealing. Thanks again for reading!
  13. Let’s start with some background. I stumbled onto the Modelships Reddit a couple years ago while doom scrolling in the middle of the night trying to get my infant daughter to sleep. I became pretty fascinated by the intricacy of some of those builds but didn’t have the time to even think about getting started back then. A few months back I started toying with the idea of giving this a shot and ultimately couldn’t shake it. I don’t have any prior experience building models, but for someone with a desk job, I’m moderately handy and have done a fair amount of work on my house over the last 8 years. After some research and deal hunting, I ended up selecting this kit, along with some tools and supplies to get started. I was already pretty well into this build when I found my way to this site, so the rest of this post will primarily be a reflection on the first half of my first build, and I’ll try to transition to more of a true build log once I’m caught up. So far, my impression of the kit is that it is exactly as advertised. It’s very approachable for a beginner. The instructions are pretty clear and easy to follow, minus a step or two where the text got scrambled somehow. There are even some tips and contextual narratives mixed in for good measure. The first dozen or so steps were straight forward and probably don’t need to be rehashed here. The first real lesson for me came when I had to attach the knee to the transom. Despite the instructions calling for slow CA, I used quick CA as that was all I had on hand at the time. I proceeded to nearly glue my fingers together and ended up with quite a bit of excess, which you can see in the second photo. I now have slow CA as well. The other problem was that the transom ended up slightly off center, which led to a lot of sanding later on, though I managed to adjust for it. I was also slightly off center with 1 of the 8 frames, though now that I’ve gotten the side planks on, I don’t think it hurt me too much. Attaching the side planks to the frames ended up being not as bad as I thought it might be. At first I had some difficulty at the stem since it’s not easily clamped, but I managed to find a way to grip it and drip enough fast CA to get it secured while the slow CA set up. The rest of the side planks were affixed with white glue and clamped. Several rounds of sanding later brings me to the last two photos for this post. I’ve already made a bit of progress from when these were taken, so I should be ready for another post in a few days. Thanks for reading!
  14. Appreciate the tip Allan. I actually found out about that series—and the promo they were running for site credit—right after I bought the skiff. I may move to that next.
  15. Hi everyone. I found my way here upon after it was recommended by several people on the ModelShips subreddit. I started the Skiff kit from Midwest a few weeks ago and I’m happy with my progress so far. I just finished fairing the frame and bottom plank. I’ve had some glue incidents but nothing that can’t be fixed (or covered up). Glad to be here.
