Thanks Roger
I will more than likely build this just as I have always built my airplanes. I will trace out the bulkheads in AutoCAD, print them individually, glue to the wood and cut them out with my bandsaw. I will cut stringer slots in the bulkheads. Once all the strips are glued in, I will start adding the planking.
Once everything is planked and sanded, I will fiberglass the hull.
My question is primarily what kind of wood I could use for the bulkheads and stringers. I was thinking of doubling wall paneling for the bulkheads and ripping white pine 2x4's into 1/4" square strips for the stringers. I can buy these in 16ft. long so all the stringers will not have to be spliced.
Thanks again
