MarcinPrzybys
Members-
Michał started following MarcinPrzybys
SaltyScot reacted to a post in a topic:
Endurance by MarcinPrzybys - OcCre - 1/70 scale - upgrade
Giddy Gibberish reacted to a post in a topic:
Cathead reacted to a post in a topic:
Thank you! Usually I use one layer of paper tissue and pva glue watered down. Wet it and try to pose to look realistic. Then painting with acrylic paint as a base but in most cases I prefer oil paints to get final result. Hope that will help ! Try it ! It’s really satisfying technique and not too complicated!
I think I more or less finished the deck construction. Most deck furniture is placed there only for photos. Whole Endurance will be weathered but this I left for last… I found that the bow is out of proportion in the occre kit and had to modify it slightly. Is it spot on? For sure no but I think looks better
I spend some time trying to figure out bench/skylight. After few attempts and tests I think this is closest to original and possible to build. My main idea is to print the core and cover it with wood. I prepared rig to glue together four covers. Each window have grooves to position brass 0,2mm wires.
I came up to the same conclusion as @clearway… Tomorrow print it and will see how it looks. 6mm diameter
- 206 replies
- Endurance
- Shackleton
