MarcinPrzybys
Members-
Everything posted by MarcinPrzybys
Thank you! Usually I use one layer of paper tissue and pva glue watered down. Wet it and try to pose to look realistic. Then painting with acrylic paint as a base but in most cases I prefer oil paints to get final result. Hope that will help ! Try it ! It’s really satisfying technique and not too complicated!
I think I more or less finished the deck construction. Most deck furniture is placed there only for photos. Whole Endurance will be weathered but this I left for last… I found that the bow is out of proportion in the occre kit and had to modify it slightly. Is it spot on? For sure no but I think looks better
I spend some time trying to figure out bench/skylight. After few attempts and tests I think this is closest to original and possible to build. My main idea is to print the core and cover it with wood. I prepared rig to glue together four covers. Each window have grooves to position brass 0,2mm wires.
I came up to the same conclusion as @clearway… Tomorrow print it and will see how it looks. 6mm diameter
- 179 replies
- Endurance
- Shackleton
To conclude my findings… Interior photos suggest that there was electricity on board and it was used. I’m pretty sure that those are ceramic insulators like those below Placement and purpose is best explained by sir Ernest himself… The question still remains whether there were any lights illuminating deck before Endurance was trapped by ice…
During the weekend I don’t have access to my workshop so done some modeling. I didn’t like the engine so I changed it. Triple expansion steam engine with boiler. This is the closest I can get considering no reference at all. And no info what brand of engine Endurance had… One inch cube as a scale reference.
Thank you! I could consider it. I think I would need to print it in more user friendly way but why not But first I need to test those elements and see how they work and look. Potentially you will be interested in everything with boiler and steam engine or on deck accessories? My plan contains all polar expeditions accessories like sleds, ski and crates…
Hi ! This is my first post here so hello everyone! After almost three years I’m starting new project. As you can guess Endurance. Plan was simple, not to complicate set, fast build, a lot of fun… But I started doing research. As far as I like OcCre sets this one have a lot of simplification and I’m trying to upgrade it to some level. Right now only small part in construction but many hours in 3D software and on printers to get best representation of Endurance equipment. This is my humble beginning of long journey hopefully with better ending than polar expedition:) Marcin
