Nelsons Dockyard
Members-
Everything posted by Nelsons Dockyard
I have also made an error in fitting the balsa centre #47 and top #48 flush to the back of #46. The frame #2 is angled, therefore these parts need to be offset to retain that angle. Will have to remove the whole section, take it apart and rebuild. Obvious now but damn these instructions. Before I continue and try to see where it went wrong, I will carry on with planking the hull.
Have hit a problem. The planking should meet the galley board on the edge, not 1/3rd down. By leaving it like this, I am guessing it will make fitting the window frames impossible. Looking at other build logs, there are 6 full planks and the part plank filler have been used. I only have 4 and a filler. Without starting the planking lower (which is wrong as the knees give you the start point) or adding more to the top beyond the knee edges (which will raise the board too high and make fitting the rest of the rear galley impossible), I can’t see how this can be achieved.
Fitted the galley board to the rear and completed the planking. Shaped the last plank to meet the Galley board. Not brilliant, but should be ok with some filler and a bit of sanding. The gap through to the lower cabin is very small and as I want to light this cabin up, I may need to remove the support between the red mark. Will use a small metal rod to keep some support there.
I decided to build the bottom galley board first, #46, 47 and 48 so I could achieve the correct shape for this and the knees. I used the parts from the original kit just in case I made an error. Once happy with the angles, added the back planking except for the last top piece. This needs to be shaped so it meets with the underside of the gallery board so will wait until I am ready to fix these parts permanently.
Rear Gallery. This is highlighting my inexperience with these type of kits but in my defence, the supplied instructions are sadly lacking any real detail. This part seems to have caused others problems in the past so I am going to go into a little more detail with this to assist others who follow. Apologies if this is too deep for a build log and should be shown / discussed elsewhere on the site. Referring to EdS build and PeteB’s help, the gallery is not flat but curved (window frames #54 and 56 give you the correct curves required). Not only does this apply to the gallery boards and windows, but seems it also applies to #31 the support former. See picture 028b, the lowest red line. Courtesy of PeteB. Rather than try to bend and shape this, it’s 4mm thick, I plan to put a curve on #114 to achieve a visual bend. But…..on the earlier kit I have, there are dotted lines on former #1 indicating where the knees are fixed. This intimates that #31 is straight and not bent. See picture 028d. If this is the case, parts 27, 28 and 29 do not give the correct upward curve. In fact they give you downward curve. As a result, you need to shape and adjust these parts to give you the required upward curve. I also fixed #27 to the far edge of the former which will give solid fix for the hull and gallery planks at this meeting point.
Not sure what’s-up next. Different builds have taken different approaches and noted various pitfalls along the way. 1). Do I start the hull planking. If yes, where do I start from. Top to bottom, bottom to top, lower deck line and go up and down? 2). Do I fix the rear knees #27, 28, 29, 31 and then plank that section first. As noted in EdS build log, that makes clamping easier and gives a reference point for the hull planks to finish. If anyone wants to wade in with help or advice, it would be most welcome. While thinking it through, I will face all the gallery windows with the kit supplied mahogany 0.7 x 2mm strip.
Onto the rear upper deck. Assembled and fitted the last bulkhead which is very tight to the rear mast so check and double check before permanently fixing. The centre of the bulkhead seemed very thin and had a slight bend so added an extra piece of wood to strengthen it. Also added another piece in the centre to give the deck something to bind to and take out any remaining bend in the bulkhead. Deck went on without any dramas and now on to planking.
Planking completed except the edges. Need to shape the formers prior to fitting the last edge planks. Lovely trip to St Katherines dock, London last weekend. Annual festival of the Dunkirk small boats along with the Royal Barge Gloriana. Also went on board the Viking replica ship which just completed its 2 year voyage from Norway.
Front deck back bulkhead fitted. Used a spacer to stop it falling backwards. Front bulkhead also fitted again with a spacer to stop it falling backwards and to give a stop point. Marked the deck with a fitting line to get the correct angle. Note: If following this example, make sure the mast fits before fitting the back bulkhead and that the mast hole on the lower deck is filed out before fitting the deck.
Planking well under way but need to order some more supplies. Made up two more bulkheads. 1 for the Quarterdeck cabin and one to go under front deck. Not sure how far back this will go and if I want side bulkheads. Hoping to add another LED and open 3 cannon ports but on checking the plans, 2 of the ports protrude into the frames. Not sure moving the ports is going to work as they will be out of line with the others and look like a dogs dinner. Back to the original build to see what can be done. Will also see if I can open up the rear cabins in anyway by removing some planking behind the stern gallery.
Next up, the quarterdeck. Attached a back bulkhead to the lower deck cabin and checked it fitted before fixing. As with the lower deck, it was slightly out but after a little filing, all was good. Glued and nailed in place which is when I realised the deck didn’t quite reach the end of the rear frame #1. Added floor diamonds and started preparing the planking.
Next up is to add the centre bulkheads on the main deck. As Ed did, I am making them longer and adding sides. I want to light the ship up, so I cut 3 windows into each side and put an LED light behind them. I used cotton for the window crosses and added a piece of acetate to keep them in place and give a bit of blur to the LEDs. Added 2 doors to the rear bulkhead. Fixed them in place along with the kit supplied bulkheads. Had to reduce the height slightly to account for the planks. I used a spacer to get the correct depth to the former #7A and small spacer butts so the front bulkheads don’t move.
As Ed stated in his build of this ship, not sure how much of the rear cabins are going to be visible so went for black and white diamonds. Cheated a bit on this. Painted the white base then marked the lines with pencil. Overdrew them with the Staedtler and inked them in. Did find some vinyl dolls house flooring which was the exact size I wanted but decided I would get more satisfaction from doing it the other method. I am hoping to open up light into the cabins if I can later in the build so in hopes that I can, I have added LED lighting under the cabin roof.
Added hatch box but first added planking to the base. This was going to be a trail for adding decking so used kit supplied mahogany strips and stained them mahogany. This was too dark so decided to use Tanganyka strip 0.5 x 4. See next post. Attached main deck 23 and 23A. Formers all lined up well, but it didn’t sit straight down the centre line. Filed out a couple of former notches and all was good. The instructions say to mark deck planking with a pencil, but I wasn’t keen on this method. On the older kit I had, the deck was marked with black lines, but this wasn’t brilliant either. Decided to lay individual planks using a 3 butt system. Saw on a video that someone had used black cotton to imitate caulking. This seemed a good idea so practised on the hatch box first. Results were ok so went for it on the main deck. I used Tanganyka strip 0.5 x 4. The kit did have 62 unspecified mahogany strips which I could have used but after staining, these were too dark. Billings later confirmed these strips were for decking but no mention of it in the instructions. Cut the planks to 10cms and stained them dark mahogany (Billings 006). Should have noted a previous build log by Ed, saying it may be a little dark. It was but got around it by brushing the laid planks with a cut down brush. This gave a “weathered” effect which looks ok now. Laid the King plank down the centre line and went from there. I used a fine tip Staedtler permanent pen to mark the plank joins and nails. Apart from a silly error of not wiping of excess glue with a damp cloth (resulting in a few hours of cleaning afterwards), happy with the result.
I hadn’t planned to do a build log so marched on without pictures. I have tried to backtrack and note any issues I came across. First job was to mark all pieces with their relevant part number using the template in the instructions. Take care, as not all pieces are numbered. I spent a few hours pushing most of the parts out and putting them into little kit bags in order of my proposed build. Keel laid, Bow and Sternpost attached. Minor error. Should have attached Rabbet (#17x2) and Stern Rabbet (#18x2) before attaching to keel.
Originally, Billings sold the main kit with the fittings kit sold separately. I thought the fittings would be simple to locate and with a bit of research, found I could also buy most of the parts individually. I tried to find the complete fittings kit through various marketplaces but without success. It is available from Billings, but few outlets have it in stock, and the cost is approx. 75% of the complete kit which now comes with all the fittings. Decision made, buy a new kit New kit arrived and the first thing I noticed is it is laser cut. The original had to hand cut from multiple pieces which was time consuming and prone to size differences. Billing instructions are somewhat sparse but as they clearly mention, the kit is for experienced model makers. So as many have advised, read, check, measure, re-read, re-measure and check again.
I didn’t like the pins, so this time I glued the planks and held them in place temporarily with larger removable pins. I steamed the planks, bent them into shape and then left them to dry before fixing them on. This was relatively successful but still had some gaps and planks that didn’t sit flush to the bulkheads. Note: Make sure you file the bulkheads to the shape of the hull before fixing planks.
As mentioned above, I started this kit 35 years ago and decided to pick it again in March this year. I had contemplated purchasing the kit again but decided to continue with the original and see how it went. If nothing else, it was going to be good practice for any future builds. I continued with the planking, despite my original effort having gaps (darker planks). From memory, I soaked the planks, bent them into shape and attached them immediately using glue and pins. As the timber dries out, it shrunk and left gaps. Lesson learnt.
