Everything posted by a.sorolla
Hi I present some advances in the construction of the frigate La Mahonesa, This time it is about the construction of the chain pumps, I put photos of their realization as a complement to the explanations that appear in the monograph If anyone needs more information about this realization or any other, you can ask me, I facilitate the explanations that are Adrián Sorolla
I am posting many photos to follow the construction process of this model, as a supplement to the monograph, if they can serve the modelers colleagues who are working on this beautiful frigate, but if apart from these photos anyone needs further clarification can contact me sending a private and I will respond without delay. Mahonesa Octubre 2024.mp4 Adrián Sorolla
Continuing on the outside of the hull, we arrive at the fore ship, preparation of the curves bowsprint and the eyes of a ship: cordially
Now the manufacture and installation of chain wales, channels the masts. We begin by making the tables, which are composed of several boards. Construction of reinforcement curves In the previous photo you can see the profile that the table has to have, which is flat at the water line and with a slight slope towards the outside on the upper side, so that the rainwater comes out. Next, manufacture of the dead eye: Manufacture of bindings: The technique is to use a printing with printer toner and transferring the drawing to the brass tape, with wetting the back of the paper with some solvent liquid. thank you
This post, deals with the realization and installation of artillery bolts in gun ports battery Due to the complexity in the realization of the bolts, given the differences in thickness of the ship side, although the hole is through from outside to inside, I relined the bolts in two pieces. Artillery bolts.mp4 thank you
Hello I want to update the work done these last months on the frigate La Mahonesa, First the realization and installation of the rudder In the previous photo I want to emphasize the separation between the "rudder" and the "post" that must be minimal or rather null, to avoid that it can be placed any foreign element. thank you
Hi After several weeks of work the outer lining of the hull of the frigate is completed. The starboard side is completely lined, and the port side releases the openings made in the structure to be able to show the interior Some photos show the realization and, at the end, some details of the simplified nail of the boards . Adrián
Hi With the bulkhead closing the chamber, the "fine" carpentry is for later, now and before installing more equipment on the deck I will make the lining of the submerged part of the frigate’s hull since for this operation I have to put the keel up. Adrián Sorolla
Hi Continuing with the embellishment of the stern, this time the installation of the decorations in the stern, it is only a top decoration glued to the corning and a tiny cutlet with the name of the boat. These decorations are drawn by Fermin Urtizberea Oronoz, in 3D and relined in CNC by Migue, Miquel Rodríguez García Adrián Sorolla
Hi Modification of the decorations of the walls, the panels in the form of molding are much better Adrián Sorolla
Realization of the interior of the captain’s chamber, 1st part, the ground Adrián Sorolla
Already on other work, I have realized the escuppers of the main bridge, in the external part of the side. Adrián Sorolla
Hi Yes, I will be in Evian les Bains (Haute Savoie) in October 2024, it will be a pleasure to meet us personally Adrián Sorolla
Hi I made the stern of the frigate La Mahonesa I leave a lot of photos, if they can be useful for those who are building this frigate Adrián Sorolla
Hi I have spent a few days making the decorations of the stern of the frigate La Mahonesa. I leave here some photos of the work I am doing Cordially Adrián Sorolla
Hi, Klarsen I am glad that you have decided for this project, the Mahonese is a beautiful frigate, I am sure that you will perform this work perfectly and you will be satisfied with the result, I will be happy to follow your progress. The length of the keel is 35cm at scale 1:1, which at 1/48 is 7.3mm, in all length, the half-timbers from 64 to 70 and from number 7 to number 1 are installed on a central wooden block, I have checked the measurement of the keel drawn in the different planes and in all measures 7.3mm, in their measurements there may be some error due to the dilation or contraction of the drawing in the printer, there is on page 130 of the book a breakdown of all the measures of the important parts. The best thing would be to take the measures of the axial structure of plane 3 that is dedicated to the structure. The drawing of the timbers of the plane nº8, should only be used to develop the scroll of the timbers. Adrián Sorolla
- 102 replies
- ancre
- La Mahonesa
Hi. No, just the coincidence of the surname Sorolla, and the city of birth Valencia, Spain Adrián Sorolla
And some photos of the inside of this frigate, made with the cell phone by the openings made in the side You can see the lighting coming from the unlined parts of the decks Some details of the construction can be obaservados in these photographs cordially Adrián Sorolla
Hi I leave some photographs of the construction of the main deck of the frigate La Mahonesa. Some areas have not been lined with wood, to illuminate the inner parts
Hello The name of this frigate was " Santa Monica" alias "La Mahonesa" because it was built in the port of "Mahon" on the island of Manorca in the Baleares Islands in Spain Though not far from the denomiation of "Mayonnaise", which is the deformation of the name of a salsa called "mahonesa", which was made on the same island of menorca, during the time that this belonged to England and is known internationally. Adrián
Hi A small video of the inside of the frigate La Mahonesa https://youtu.be/TWR0ZvGBwBE https://youtu.be/Zb1aaqmCFVI Adrián
