Anybody using Chinaberry, species Melia azedarach https://en.wikipedia.org/wiki/Melia_azedarach, in ship modelling?
Commonly known by many names, including white cedarchinaberry treebead-tree, Cape lilacsyringa berrytreePersian lilac, and Indian lilac
According to wikipedia it is in the Mahogany family and has a 'timber of high quality.'
'This is of medium density, and ranges in colour from light brown to dark red.'
'Seasoning is relatively simple in that planks dry without cracking or warping and are resistant to fungal infection.'
I have several of these on my property and have to pull out the chainsaw regularly to keep them in check.
Samuel Pepys notes in his diary on 19 July 1667: "the Dutch fleets being in so many places, that Sir W. Batten at table cried, By God,says he, I think the Devil shits Dutchmen."
From the Wood Data Base:   " Due to it’s moderate density and generally straight grain, Chinaberry is quite easy to work: it cuts, planes, sands, and glues well. Perhaps the only difficulty is in its large pores, which tend to give a very open and grainy finished appearance, which may need to be filled, particularly if a smooth glossy surface is desired. "
Some use Oak and  Walnut, which are woods with open pores.  If you do not mind that the wood does not give a convincing appearance of timbers scaled down to 1:50 or lesser size -  soup bowl sized holes,  it should otherwise work.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
No thanks, no soup bowls for me! Will find some other use for it.
