I've just started the Syren. In the plans I've been unable to find the load water line (LWL) identified. Is there somewhere that may be found?
I would think the upper line of the copper plating would be it. You can see that line on the outboard profile, on the first plan sheet, I think. There is a horizontal line along the hull and the vertical station lines meet it. That horizontal line is the waterline.
Russ
