I run an IPS system too. I've searches there and cannot find an answer to my question. You use sponsors. How did you do that? Plug in? What's the name?
Norwegian Sailing Pram 1:12 Scale. 2nd boat in the learning series.
In Dry Dock:
Muscongus Bay Lobster Smack. 1:24 scale. Model Shipways, 3rd in the learning series.
Not sure what'll be next, probably the Santa Maria by Artesania Latina 1:65 scale. Unless someone has a better suggestion for a beginner.
Pride of Baltimore. Model Shipways. Clipper used in the war of 1812.
Black Falcon. Mantua Model. 18 century corsair brig.
CSS. Alabama. E. Manolie? Can't read the font. Build in Liverpool in 1862 for use in the American Civil War by the Confederates. Steam and sail, sloop of war.
Of all the things I've lost, I miss my mind the most.
A baseball cap my Dad wore.
Do you mean the banners?
Dirk is right, this is custom text that is added through a widget. This is called PHP & TXT Widget, available from the IPS Marketplace. You must create the text through an HTML program, such as Kompozer etc, and then paste the HTML into the custom text field.
https://invisionpower.com/files/file/7337-txt-php-widget/
Ongoing:
