Here we are on October 21st having completed planking the hull, having made the rest of the gun ports and having applied a first coat of mat varnish. I also used the sanding dust - which I kept in a bag - to fill up the nail holes and other mistakes I had made. Mixing the dust with some varnish makes for a nice filler that matches the wood well.
The hull is far from finished in it's current state. Some more sanding is needed. I am aiming for a smooth surface with no more than 0.1mm irregularities. Scaling up 0.1mm by 90 gives 9mm which would be plenty much and unacceptable for a real ship - I think.
Despite the minor issues you encountered...the hull looks nice!
Most bad things tend to happen below the waterline, but it's a fairly common practise to paint the hull white beow the waterline.
So, with a bit of filling and sanding...paint...problems solved! ;)
WIP: No ships atm...sorry!🙄
Completed: Greek bireme - Dusek - scale 1:72
 Louie da fly: "I think it requires a special kind of insanity to choose a galley to build a model of."
