After many years out of ship model building at a basic skill level, I am working on MS Syren. I am installing the carronades. I have tried different methods to duplicate the setup that Chuck shows in his instructions but have not been able to get acceptable results.
Any suggestions would be greatly appreciated.
Thanks, Harley
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
Thank you for the great pictures. How do you get the lines to lay flat?
Cheers, Harley
Cheers, Harley<p
Harley,
One method I have seen is to use a pin to wind the lines around and lay the line flat between two sheets of stiff plastic (similar to the plastic you might get covering the box in which a business shirt is displayed for sale). These sheets are cut down to about 1cm x 1cm and the line is slowly wrapped around using slightly diluted white glue to keep it stiff. Remove the plastic and the pin and you're done. I'm sure it will take some time for this technique to be learned, but as line is not all that expensive, and you'll need to make a few of them in all your models, it might pay to practice this a bit.
Sorry I can't show you a diagram or photograph, and I hope you understand how this might work. If you picture it in your mind, you might be able to work it out, and even improve on it.
Steve
Steve D
Member of the Australian Society of World War 1 Aero Historians
http://www.ww1aero.org.au/
Cheers, Harley
Hi, Harley! Model on which I gave the reference, not my production therefore as lines to lay flat in it I not are made I can to tell. In the models I apply almost such method as described here Steve to receiving lines to lay flat.
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
