I have a very basic question so that I don't stuff up before I've barely started.
I'm building the US Constellation from Artwsania.
I know my bulkhead peices need to be at right angles, but should I be lining them up at the top or the bottom?
I have started lining them up at the top, but the bottoms don't line up, is this normal?
Hi Teetree.
Simply put - especially for me - The bottoms don't line up because of the way the hull is designed, you'll see this in the pictures.  The tops line up decause that's where the deck lies. I completely messed up my first attempt 40 years ago and gave up until recently - no internet for help back then!
Have a read of these tutorials Hull and Planking Lots of info there.
[Also I would suggest starting a build log in the 1751 - 1800 area.  Loads of help and advice to be gained by that.
Read this on how to name your log too! Naming your log]
Edit - see you've already done this!
Bob
Bob
Current build Cutty Sark, Mini Mamoli
Finished  King of the Mississippi
No trees were harmed by this message, but an awful lot of electrons were put out.
13 minutes ago, Bob Fraser said:
Hi Teetree.
Bob
Thank you soooo much, those guides will be very useful :)
