On 7/30/2020 at 6:01 PM, Davy Jones said:
Finished the keel. I think it looks ok now its sanded.
I also attached the rudder This was quite fiddly, it took alot of fitting the re-fitting but all went well I had to be quite carefull with the rudder Gudgeons i think thats what they are called, These are made out of a lead type metal and marked very easily.
Davy.
I am making the same model, I am up to attaching the rudder.  The directions for this model aren't the best. I can't figure out what to use for the pintles for rudder Gudgeons.   What did you use for the  rudder pintles?  Thank you David
Edited by Sparky21
