Hello
I need to buy:  A) a pair of small V-blocks and a B) pair of really large V-blocks. Do you have any buying advice?
(e.g. what brands, what features, where to buy from etc)
Background:
A. SMALL SCALE
I need the small v-block for working at small scale
e.g. this sort of thing:  (e.g. 40mm x 32mm x 32mm).
https://www.amazon.co.uk/Precision-Engineers-VEE-Blocks-CLAMP/dp/B08W4M44JH/
What about something more exotic like the Tormach V-block set?
They sit "below flush" at the sides which is quite clever as allows you to clamp the whole block in a vice, or use it on its side
33243_mulit-use_v_blocks_and_clamps_img_
https://tormach.com/90-degree-v-block-clamp-set-matched-pair-33243.html
Wait, here is a video!
B. LARGER SCALE
A friend has a pair of large "Seven inch" (180 x 115 x 45mm) v-blocks which he says he uses "every day" for all manner of random model-making task. (e.g. holding things down, holding things at 90° whilst glue sets etc:
i.e. This sort of thing:
200x100x140mm+GRADE+2+VEE+BLOCKS+(PR)_0.
https://www.zoro.co.uk/shop/measuring-and-test-equipment/vee-blocks-and-clamps---steel/200x100x140mm-grade-2-vee-blocks-pr/p/ZT1017529X
Although that get pretty expensive (GBP200+)... also it's rather irritating to have the writing on the top.
Also would it be better to have a round or square cut trench down the middle?
Any thoughts?
J
Regarding the small (c. 32mm) V-blocks, I need them to be:
a) "pretty accurate"
i.e. Accurate to say 1/1000 inch  (0.02mm)
b) made out of good quality hardened & heat-treated steel, so that they will resist being accidentally filed/dropped etc
Budget: £40? (but hopefully a lot less)
e.g. Brand: "White Hinge" (c. £35)
2X Precision Engineers V-Block Clamps - 1"/25mm
https://www.amazon.co.uk/gp/product/B077Q7271M/ref=ox_sc_act_title_2
e.g. Cromwell Tools - (c. £40)
Oxford.32x42x32mm WORKSHOP VEE BLOCKS C/W CLAMPS
https://www.cromwell.co.uk/shop/measuring-and-test-equipment/vee-blocks-and-clamps-steel/32x42x32mm-workshop-vee-blocks-c-w-clamps/p/OXD3702310K
e.g. Bluefox Tools (India) ) (c.£32)
Precision Engineers Vee Blocks Clamp Set - V Block Matched Pair 1-5/8" x 1-1/4"
https://www.ebay.co.uk/itm/Precision-Engineers-Vee-Blocks-Clamp-Set-V-Block-Matched-Pair-1-5-8-x-1-1-4-/164123187633
e.g.Buy Brand Tools - BBT (c.£23 + incl postage)
"Precision V-Block Clamp Set"
https://www.buybrandtools.com/acatalog/precision-v-block-clamp-set.html
In general, are there any brands that you recommend for tools?
And are there any brands to avoid?
With thanks
J
PS I do also still need to buy some much larger ones  c. "seven inch"
Edited by ship69
