What exactly are you trying to waterproof? Is this for a floating model hull, or just to prepare for painting a wood surface?
A functional hull should be glassed outside and resin inside.  It need not be epoxy, polyester resin is cheaper and will do the job just fine.  The glass helps "shrinkwrap" the hull so any seams that open even a little bit don't let water in.  Without the cloth, the resin will just crack, water will get in and swell the wood, expanding the crack, and deforming the hull.
Building Wooden Hulls for RC
Jerry Todd
Click to go to that build log
