Here we go again, beginning the next model in a journey toward learning this wonderful craft. I’m also continuing the trend of modeling something a little bit bigger with every new entry.
The Albatros by OcCre. An American schooner which I do not believe is meant to directly represent any specific, actual ship. Still, a good deal larger than the smack I just finished before Christmas.
The first step was to open the packaging and cut some parts free.
I have to admit that I was a bit disappointed by the plywood. Maybe I was just spoiled by the previous kits but I’d gotten used to the solid wood. That didn’t stop me from plowing ahead and directly into my first challenge of the build.
The central spine of the ship was curved, rather severely by my inexpert estimation. So I looked across other build logs here and found out a couple of things. This isn’t an uncommon occurrence, and the most recommended correction is to use a jig of some type to hold the spine straight. I decided to take a different approach. I glued the first few frames in as squarely as I could and then proceeded to add additional bracing between them.
Here, I have the deck temporarily in place to hold things square while the glue on those braces dry. Doing it this way was a slow, meticulous process but resulted in what I think was a very satisfactory result.
They may not be perfectly even, but everything was square and the deck will be flat. The braces will ultimately be hidden anyway. Next came planking of my deck.
The instructions recommended drawing lines on the planks every 100 mm. I opted for every 4 inches, which allowed me to divide that 4-inch span into 4 equal parts. Doing that would allow me to get a 3-butt shift pattern of 1-4-2-3.
From there I could cut my “planks” into 4-inch lengths, colour the edges with graphite to simulate tar caulking, and start planking away. IMG_2593.thumb.jpeg.0bae553d75e234cb82e5b5f2262e76d6.jpeg
A little bit of sanding flat and I got my 3 deck pieces ready to go. I’d also skipped the wall where the cabin door will eventually go, so planked that the same way.
Which brings me to where I stand now. The next step in the instructions is to glue the main deck in place, but I’m considering staining it first. The big decision there will be to use the “oak” or the “pine” stain. I’m not sure which would have been the more typical wood to use, so I’ll probably end up staining a few scraps to see which I like better before committing to the actual piece.
Im excited to have a ship to work on again and I’m ready to jump into this next adventure.
  • 4 months later...
Have you ever been working on something that you truly enjoy, get distracted by some life event, put it down and not touch it again for four months?
Yeah, me too.
The good news is that I have finished school, having graduated and gotten a job I finally have time to pick up my toys again. Now where did I leave off?
Before I had set things down I had finished planking the decks and cleaning up the holes for the masts.
I was really proud of them at the time (as evidenced by the number of photos I’ve found on my phone) and still can’t believe how well they turned out. I had also been debating what colour stain to use and had settled on pine.
This, too, I was happy with and feel like it gives the correct look. Worth noting is that the stain didn’t fully saturate in areas with glue residue (which should not have come as a surprise). I’m not really sure how to fix that for the future because a little glue squeezing out is typically not a bad thing. Sanding it down smooth was either not sufficient or wouldn’t have made a difference because the “planks” are so thin anyway.
Next I had assembled and glued down the decks, making the model finally begin to look like a ship.
My last addition before the hiatus was to add on the filling blocks to the bow and stern.
And with that I promptly walked away and didn’t get around to picking it back up until yesterday.
Sanding the frames has never been my favourite job and that probably contributed to my having left things alone for so long. A few hours of carefully carving away the excess followed by sanding things smooth has resulted in this:
Granted, I have only tackled the bow, but I think it’s becoming presentable. If nothing else, it’s tolerably even between the two halves. Next step is going to involve doing something similar to the stern end, then I can get to planking the hull which is a much more enjoyable endeavor.
Anyway, that is where things stand for now. Maybe I’ll post another update before 2025.
Edited by WizardOfOs
Picking up where I left off, I next moved from the bow to shaping the stern.
Hollowing out these ribs was proving very difficult using sanding sticks. Yet another example of me discovering that a job can be made much easier once you choose the correct tool to do it.
Lesson learned and now I have this file to help face similar jobs in the future. I also had a slight gap appear under the decking toward the rear and added a bit of scrap wood to fill that gap. My hope was that it would help to made a more solid point of contact later on.
To this point I had just been laying the model on my cut mat, but that presented some challenges with keeping the sides free of debris. As a result, I quickly put the stand together. I have not decided if I’ll actually use this stand when finished, but it’s a good holder for building if nothing else.
Next came bending the sides, something I was very nervous of.
The water bottle (filled with near boiling water) served double duty in allowing me to soak the parts and in being approximately the correct diameter for the bend. You can see here that I got a slight kink at the foremost cutout, something that has persisted in causing me problems ever since. More on that to come.
Once bent, I planked the sides in the same way I did the deck.
In retrospect, this was probably a mistake. The actual ship wouldn’t likely have planking done this way here. We learn and we move on. After staining, I gradually glued the parts on, moving from back to front.
That strategy worked very well. While I was waiting for the glue to dry I bent the stern board.
Water bottle to the rescue again. Once I got all the way to the front, here is how things lined up:
a bit of a gap toward the bottom, but meeting near perfectly at the top. The unfortunate problem I’ve encountered is that they’re not smoothly curved. Rather, they’re well curved in the area of the first cut out then flat again to the bow. I’ll need to find a way to round them before I glue the upper rail in place.
Any suggestions on that? It would be hugely appreciated.
Powering forward, I glued on the stern board and it looks excellent to my eye from both inside and out.
Finally, I’ve just drilled the two extra holes for the anchor ropes.
So questions and plans for next steps:
1) How am I going to round out the upper half of the sideboards around the bow?
2) The instructions seem to imply I should use 2x4 mm walnut strips to line the deck as waterways. If I glue them in as indicated, they’ll cover the bottommost portion of the wall higher than the bottom of the cutout gun ports. I suppose that means I will need to cut channels into them to match the ports. Should I do that before or after they’re glued in place?
Things to think about. I’ll make a decision after I have the strips bent into shape.
  • 8 months later...
After doing the Bounty Launch as my first model, I'm starting the Albatros now. I very much like your planking pattern and your use of braces for ensuring hull structure.
On my model I'll try some weathering techniques.
Will keep following your log!
Current build:
Albatros - Occre - 1:100 (weathered)
Completed builds:
Bounty Boat - Occre - 1:24 (fully planked hull)
  • 2 months later...
Alfredo, thanks for the kind words and I’m glad you’ve found this log helpful. I can hardly take credit for the pattern, that was shamelessly stole from elsewhere on this site. I must admit that I do not remember who from anymore. I will be subscribing to your build as well and following along there.
As for continuing my own, life got in the way for a while. September of 2024 had me working a new job which since went away. Now I have another in the works and while things have not exactly calmed down, maybe I have a little.
To the model. I bent and glued in the walnut “waterways” to the inside of the ship.
Doing so was much easier than expected and gave a nice contrast to the stained decking. I think a quite handsome result.
Continuing that along, I did some shaping and rounding at the rear and think it provides a little bit more detail than simple square joints. You may also notice I notched the cross piece slightly for a better fit.
The bow was a simple addition.
And I cut away any material blocking the gun ports, which I am not entirely happy with but have come to terms with it being the best I could do.
My complaint is that the spacing between those ports and the deck is not consistent, which I suspect will cause problems later when I place the guns.
Then came planking.
And planking.
And planking.
And, you guessed it, six long months of planking.
I followed along with the instructions as written in the kit and am not impressed with my results. Next time I will try to taper the boards and do it “correctly” but it is a learning process and I had to do it wrong before learning why it was wrong. One thing I got correct was leaving the nails proud so I could easily pull them back out.
Doing so left me a model looking more like a ship than it had up to that point. I shaped the bow as best I could to fit in the keel and then set to wood filling.
It hurts to have something starting to look nice and then turn it into a lumpy, pasty mess. Trust the process.
With a considerable amount of sanding I got here. A hull I can be proud of, even if it’s not perfect. That brings me to the point where I’m diverting from the kit instructions. It would have me add the second layer of planking, but I think it makes more sense to add the keel first.
By doing that, I would have a final point to plank up against which I think will give me a better looking final product. No way to know until I do it.
So that’s where we are. Slow and steady and working away while dealing with anything that come up in the “real life” portion of things.
Picking up from where we left off, I glued the remainder of the keel in place. No photo of that available because I forgot to take one. Then I began to glue out the outermost layer of planking.
I did that in much the same way as the decking, colouring the edges with graphite and gluing them line by line. Once they were all in place I stained them the same colour as the deck and cut out the gun ports.
I was a bit concerned about getting the correct shape at the bow and making sure the bowsprit would fit correctly. So I quickly cut the dowel to length and did some (very rough) shaping.
I will come back and clean that up before permanently fixing it in place. For now, it was a good guide to get everything filed down and fitting well.
Next was to stain the remaining hull red to his any imperfections between the second layer of planking
You can also see the finished keel and the hole I drilled for the rudder. Then came laying strips of veneer.
Which was a long process, but infinitely more enjoyable than the first planking.
Similar to the first planking, I know I did not do it “correctly” but this was the method suggested by the instructions and I do like the end result.
A specific skill I want to learn and develop on my next model will be shaping those planks so they lay appropriately from bow to stern throughout.
One detail I didn’t like was the visible plywood in the gun ports. I cut some small lengths of veneer and used them to make casings.
I don’t know if this is particularly accurate or appropriate, but it looks better to my eye.
Finally, I glued on the strips of wood which the deadeyes will eventually be fastened to. These went on nicely and really help make the outer hull look “complete.”
I’m skipping the stern decorations for now and moving on to the railing next. The pre-cut pieces are very much not the correct shape, but I did my best to convince them to set in place.
I plan to sleep on how they look tonight and then decide if I was to take them back off and try again. It’s close enough from a distance, but the gaps are not even and they wander back and forth a bit drunkenly as compared to the hull.
  • 2 months later...
