From Great extensive research Richard Jones (Clipperfan), and I have determined that the term (Post the clipper ship era), that time after Donald McKay built his clippers...the term evolved.  The examples you have presented are of vessels, that post date 1869.  McKay was adamant about his bow secrets on his clippers and his *Naval Hood* as we have described it is only found on McKay clippers.  His unique application of this structure greatly strengthened the cutwater and stem of the bow.  It is not unrealistic to assume, McKay would utilize this feature on all of his vessels....if he used it on his last.  Clippers like the Great Admiral  and the clipper frigate Admiral Webb were typical of the clipper bow of the time.  NO McKay *Naval Hood*, supporting the stem.  Damage from high seas regularly occurred, but with Mckay's designed *(Hood)*...such disaster was avoided.  Not forgetting to mention, that the Hood also added greatly to the support of the figurehead. Edit: "The GREAT ADMIRAL was built in 1869 by Robert E. Jackson at East Boston for William F. Weld & Co., who at that time had the largest sailing fleet under the American flag. Her figurehead was a life-sized image of Admiral Farragut and still is preserved on the Weld estate near Boston."
image.png.389e1204196a3acde4a88c7cf9d2e207.pngimage.png.8239110f090ede7791b50ed7a07c5742.png
Edited by rwiederrich
Current build:
Finished build:
Current build(On hold):
On 4/18/2025 at 6:32 PM, BANYAN said:
Hi Rob, I am speaking with experience from a much later period (late 20th century).  We also referred to 'naval hoods' as the metal hoods (covers) put over the top of the naval pipes once the cable was stowed/run out.  Some ships had an angled entry/cover built-in as part of the pipe which simply required a cover plate put on.  Other ships had a full hood that was partially inserted into the upper part of the pipe over the cable at the upper deck level. They were used to stop/minimise water entering the cable lockers through the naval pipes (metal trunks from deck through the deck(s) to the lockers).  Perhaps an 'interpretation thing?
cheers
Pat
Pat...Hi.  Yes I have heard of these Howes *Hoods* that you are speeking of.  However, as I mentioned to Scott...this term probably underwent a bit of  transformation, since McKay's use, and Duncan McLeans description of it on McKay clipper bows.
Photographic evidence proves, McKay clippers possessed this unique feature.....all else did not.  It is also very reasonable to assume since McKay used this feature on his last clipper...he used it on all or most of his clippers....with the extreme exception example of his massive Great Republic.
Rob
Current build:
Finished build:
if that is the case, what exactly is the hold that McKay used - i.e. what does it look like - the only think iI see in the two pictures you show is maybe
an enlarged bow below the figurehead?
the drawing of the bow of the Flying Cloud in Hall's report (which he may have gotten form Mary McKay) is this:
and the McKay drawing itself is this:
I'm trying to figure out what you are referring to
are you referring to A or B or something else?
thanks
Scott...all those drawing are not showing the location of the Naval hood in proximity to the stem of the cutwater.  McKay never drew the hood on any of his drawings...probably to protect it). Here is our drawing of Glory of the Seas...you can see the large Hood under the bowsprit and above the cutwater.  Below the hood (with its carved liefing's) is the ornate cheek that adorns the stem and is under the feet of the figurehead
Current build:
Finished build:
The top trim of the Hood is the trim of the planksheer.
Rob
Current build:
Finished build:
Champion of the Seas 1854 definitely shows a structure above and behind the figurehead .  Not super clear, but evidence the figurehead is not simply pressing up against the bowsprit.  there is evidence of ornate cheeks as well.....similar to Glory of the Seas.
Rob
Current build:
Finished build:
Thanks, now I understand what you are referring to on the Glory - harder to see on the two photos you posted
none of the contemporary paintings of the Flying Cloud are clear enough to see if she had a substantial hood as the Glory did
but, if the McKay hull drawing is to be accepted ether was not room for a substantial hood - maybe enough room for
a thin one with the planksheer brought forward over the figurehead (as is shown in the first photo)
sorry - just reread your text 0- the photos were to show not having a hood
but the rest of what I wrote stands - the McKay outline does not leave enough room for a substantial hood
McKay left off all the bow details from his drawings......even from his half hull lofting models.  here is a rendering made by Rich Jones....of Flying Clouds bow with the hood.
Rob
Current build:
Finished build:
for what its worth - the model of the Flying Cloud in the Boston MFA (from about 1916) does not show a hood - the figurehead is pressed right up to the bowsprit
the Currier & Ives litho also shows the figurehead up against the bowsprit (as best as I can tell)
I can see how it could have been done but I've seen no evidence that McKay put such a hood on the Flying Cloud - maybe he figured out the hood's
strength after he built the Flying Cloud (the FC was quite early in his clipper days)
Scott
Even Mckay's own hand drawings of Star of Empire and Chariot of Fame...shows an extended stem far outside the typical reduced version seen on line drawings.  It is unclear from this image...ut it can be devised it is a more pronounced and curved prow then on other protypical line drawings. Notice the extended *Beek* underneath the bowsprit?
Rob
Current build:
Finished build:
Scott
There is strong evidence the Naval Hood was on the Staghound....prior to Flying Cloud.  We cannot be distracted by bias , blindly ignoring a practice that was clearly evident on his last clipper.  Proof evident.  And no other shipwright employed this unique structure.  This is why Rich Jones and myself have dedicated over 18 years of our time to researching and re-imagining the secret structures of Donals McKay's fantastic clippers.  Richard Jones (Clipperfan) is more of a zeolite then I am concerning this overlooked structure.   Maybe he'll pipe in......
Rob
Current build:
Finished build:
here is a close-up of that dwg
It is hard to tell because the hull is drawn as transparent - the planksheer does seem to extend up the back pf the figurehead
but it sure does not leave much room for a strong hood
Scott
can you point me to the evidence about the staghound
ps - I'm not a zealot either way but remain to be convinced
Scott
One of the difficulties we are having with this interpretation is that the bowsprit is flexible and to secure the figurehead to it, would surely mean you may lose the figurehead during bad weather...due to extreme flexure and sheer.
Current build:
Finished build:
16 minutes ago, sob said:
I do not see any evidence that the figurehead is secured to the bowsprit in the Flying Cloud
The difficulty with it NOT being...if it could be. would be the feet of the angel are the only things securing the figurehead to the stem...that and possible a bit of the aft of the wings.  Atheana, the Indian goddess figurehead of Glory of the seas is secured from her back to the naval hood and her feet to the prow of the stem.  Securing her very well.  This is in part why we feel the hood was a very significant structure to the entire security of the stem and cutwater. Simply sticking the figurehead to the tip of the stem is hardly secure.  Duncan McLean's very detailed descriptions of Flying Cloud and Stag Hounds structures is our source, in part.
Rob
Current build:
Finished build:
yes, Duncan McLean's article mentions that the Flying Cloud had "navel hoods" that have carved work on them but it says
"where the line of the planksheer and the carved work on the navel hoods terminate, she has the full figure of an angel on the wing" i.e., the
figurehead starts where the navel hoods end
which does indicate some sort of framing that carried up the back of the figurehead
Scott
Scott
So, just follow the line of the planksheer up that forms the top edge of the hood....there is where the figurehead is located.  Look at the image of Glory of the Seas Atheana.  she is under the hood and she is where the planksheer and hood leading edge terminate.  the figurehaed must firmly be secured to the bottom of the hood is if is to survive....just like GotS.
Rob
Current build:
Finished build:
what I think you are referring to as the hood in the Glory photos go past the feet of the figurehead which is not
how I read the McLean article and I still do not see enough space in the McKay drawing for anything like what Glory has
seems to me that the definition of navel (or naval) hoods was basically the same from the 1700s to the 1950s
and that was beams around the hawse holes to support them or to guide the anchor rope into them
I have found no indication that the term navel hood was applied to the kind of beak that the Glory had above the
figurehead
so I think we will just agree to disagree on what the beaks were known as
if those beaks were only on McKay ships they sure could have been an important development
it does appear that I need to work some on my Flying Cloud drawings to better conform to what McLean describes
Scott
some more research - Duncan McLean wrote articles about 161 (or so) ships launched between 1850 and 1856.  I searched most (but not all) of these articles for "hood".
I found mention of navel hoods in only 8 of the articles - only one McKay ship - the Flying Cloud
here are the quotes from those mentions
Flying cloud 1851 – McKay
She has neither head nor trail boards, but forming the extreme, where the line of the planksheer and the carved work on the navel hoods terminate, she has the full figure of an angel on the wing,
Samuel Lawrence – 1851 - Curtis
She has a light billet head, ornamented with gilded carved work, and her trail-boards in their sweep take in the navel hoods and make a handsome finish forward. The line moulding of her planksheer is carried forward to the extreme, and rise with the bow in a bold and regular sweep, and harmonizes well with her sheer.
Polar Star – 1852 - Foster
She has a carved and gilded billet-head, and her trail boards and navel hoods are also covered with ornamental carving. The mouldings of her planksheer and main rail are continued to the forward extreme, and terminate in a point in the rear of the head, and their outline form the head-boards.
Beverly – 1852 – Curtis
She has a carved and gilded head, with ornamental work along the trail-boards and around the navel-hood
J. Montgomery – 1852 - Badger
The sweep of the trail boards takes in the navel-hoods, and makes a very neat finish forward.
Orient – 1852 – Raynes
She is planked up flush to the planksheer, has rounded or convex lines, and a carved and gilded billet head, with ornamental carving upon the trail boards and navel hoods. The moulding of the planksheer is carried forward to the billet, and forms the lower outline of her head boards
Ocean Pearl – 1853 – Magoun
It is a neatly carved and gilded billet, and its lower outline is the continuation of the moulding of the planksheer; and the trailboards and navel hoods are blended in one, and are ornamented with carved work.
Webster – 1853 – Raynes
She has a carved and gilded billet head, and carved work upon her trail boards and navel hoods, and the lower outline of the head boards is the continuation of the moulding of her planksheer, and its upper outline is the moulding of the outside clamp between the rack and the main rails
All of these quotes, from the time of the Flying Cloud, are consistent with the definition of navel hoods that I included in my last post
that's all for now
Scott
slight correction about the last posting
McLean wrote about 161 articles about ships launched between 1850 and 1856 not articles about 161 ships launched during this time period
a different topic but may be interesting - someone mentioned that Lars Bruzelius's site was now offline
two things:
      1/ the Internet archive archived his site and you can get the contents at
          https://web.archive.org/web/20240531215650/http://www.bruzelius.info/Nautica/Nautica.html
       2/ I downloaded the Boston Daily Atlas files and have put them up on my website
          https://www.sobco.com/ship_model/BDA/BDA.index.html
Scott
However, it is interpreted....It appears that the structure is more then just *support beams* aiding to anchor cable/chain threading.  Nearly all descriptions depict Carving and gilding on the Hoods.  Now, since no other vessel retained these McKay *beaks*, and our full grasp of Duncan McLean's description can't be entirely realized.  It is a proper thing to refer to the structure as a McKay *hood*.  But regardless as to our agreement on its naming...it is undeniable these structures were the *secret* McKay reinforced his stems on his clippers with.  Leading Rich Jones, to conclude, that every drawing and model of McKay clippers are represented inaccurately.  Glory of the Seas is the Key, without the clear unpublished photographs, provided to me by my friend and historian and author, Michael Mjelde, I and Rich would have never had the proof/evidence, of Donald McKay's ingenious, McKay hood.
Rob
Current build:
Finished build:
Scott
Which surely cannot mean anything to do with the Howes hole.  If rightly understood the termination of the hood and planksheer simply indicates the point at to where the figurehead is located.  Reference the photo I posted of Atheana on Glory of the Seas.  She does NOT rest her feet at that point...then begin her extension forward.......No...she is in general marked out by the termination of these structures.  She IS forward and, for structural purposes, bolted BELOW as well.  Still, this is not in violation of McLeans description.  If you refer to Glory as if she was Flying Cloud, in the description....it becomes very clear.
Rob
Current build:
Finished build:
