Milled Wood Dimensioning
43 members have voted
  1. 1. When you purchase milled wood as sheets, strips, or a wood package do you expect to run it through a thickness sander?
    • Yes, I expect to do some dimensioning myself
      12
    • No, I prefer to have it dimensioned so that all I may need to do is some surface finishing
      31
  2. 2. Should Suppliers specify their milling tolerances on their website?
    • Yes
      40
    • No
      3
  3. 3. What tolerance is acceptable to your needs, assuming that everything should be at or slightly larger than the size specified?
    • -.000" - +.005"
      13
    • -.000" - +.010"
      17
    • -.000" - +.020"
      8
    • -.000" - +.030"
      1
    • Tighter tolerance than 1st choice -.000" - .005"
      2
    • Greater than +.030"
      2
.005" = .127mm
.010" = .254mm
.020" = .508mm
.030" = .762mm  also equal to 1/32"
Thanks Pat!  Software won't allow me to post this up in the poll itself.
Edited by Boatsinc2000
Jeff
aka HobbyMill
Current Build: Constitution
