michael101
Everything posted by michael101
  1. thank you Jud! can you post some pics of the table and some pice of wood to show example of your roter table? thank you Michael.
  2. hello friends i see that table in the internet http://vanda-layindustries.com/html/router_table.html and i ask for shipping to israel they told me its going to cost 50 $ so all together 165$ is it worth the money ? best regard Michael.
  3. i have find this but not shipping to israel .... 5" PSA hook-Conversion for Velcro disc https://www.vermontabrasives.com/5-PSA-hook-Conversion-for-Velcro-disc.html
  4. amazon no send to israel but i think the best way is to find adaptor or to make one fo fit Hook & Loop because you can find the sandpaper disk in any store and it cost cents I thought to buy a pad that can fit the "Hook & Loop" and to glue that pad on a sandpaper of Proxxon with a carpenters glue or some strong glue and than i will be able to buy what ever i need i mean the type of the sand paper for cents I thought to buy a pad fit and paste it on the glass paper with glue Proxxon
  5. thank you all!!! Dave the problem is that they d'ont send to israel and Mark can you send me a link?
  6. hello friends! i just boat the Disc sander TG 125/E and i can say that tool is from the category : "Must have" a very good quality there is degrees guide and the table also can move with degrees guide (beside the ruler !) i just want to ask if some one has this tool and if he know about alternative for sandpapers Because for that tool you need a spacial sand paper that cam with sticker best regards! Michael.
  7. Thank you Moxis !!! i hope it will be my last question lol have you try that one of proxxon? http://www.amazon.com/Proxxon-28020-2-Inch-HSS-Blade/dp/B000S6DTT0
  8. hello Moxis i have talk with Mr Knupfer bay emal and he give me everything i need just want to make sure : beside of making planks from wood i need also to cut planks i mean i have 0.5mm * 4mm planks and i want to cut 1mm to make the plank 0.5mm*3mm can i do it with: 50 mm diameter, 0,5 mm thickness: w-krs-50-05-10 63 mm diameter, 0,5 mm thickness: w-krs-63-05-10 or i need also: 50 mm diameter, 0,3 mm thickness: w-krs-50-03-10 50 mm diameter, 0,4 mm thickness: w-krs-50-04-10 thank you again Michael.
  9. thank you! can you please give me the item number because all the web is in german and i can't understand the language also i need to check if they sending to israel
  10. i see in the proton web Technical data: 230V. 7,000rpm. Mitre infinitely adjustable up to 45°. Table size 300 x 300mm. Cutting depth 1 - 22mm. Saw blades between 50 - 85mm can be used (with 10mm centre hole). Weight approx. 6kg. so i can buy 50mm also and i need it for making planks so i no need more than 50 mm someone can recommend a specific blade with Experience of making planks? or someone can recommend o blade that can serve what i looking for from that list https://knupfer.info...ageblatter.html (Moxis thank you for posting that link )? thank you Michael.
  11. hello friends i have the proxxon table saw (FET) and i need to buy good blade for cutting / making planks my blade (the one that came with the table saw) can't cut planks even 1.5mm *5mm so i want to buy a good blade for that job which blade is the best for that job? (its not need to be only from proxxon but ni to be 80mm and 10mm hole to fit ) thanks
  12. wow thank you all !!! I have not read the posts until today But I thought on this solution Melted the tin in the mold of the wood part , on the basis of tin , Then I cut the tin around casting After that sharpened the part , and then I drilled the holes ( measured from the damaged wood piece between the holes by a pin ... ) Here are the results :::
  13. hello im working on the concord stagecoach of model expo and i want to make some upgrade for some little ply pieces so i want to cast tin and i need to make a molding for that its a very simple pieces without nothing on that it just for replace the wood piece need advice for making mold best regards Michael.
  14. i called to the store and i told hem what i need it for so he told me that i not need something expensive and he talk about that model : http://www.sparmaxair.com/product_detail.php?id=1&r=55 how is it? for the airbrush i will go on the ultra H&S Ultra two in one 125533 with: nozzle set 0.2 mm and 0.4 mm 2 ml and 5 ml plug-in cups best regards Michael.
  15. thank you all!!! now i need advice for compressor i will be more than happy if you will note which one you use best regards Michael.
  16. thank you! the point is that im leaving in israel and im not like to order expencive thing over the internet we have a good website that selling airbrush Which one to take? and he has : Harder & Steenback H&S Ultra 125503- 80usd Ultra two in one 125533- 109usd Evolution CRplus 0.15 126204-156usd Infinity two in one 126543-287usd which one to take?
  17. thank you all. the point with the infinity is that its have a stopper for not to push the batten moreand less and its will give you the same mount of color all the way ... is it necessary? because i dont want to make a damage on painting... and what make the different between single action to double action ? regards Michael.
  18. thank you all!!! someone know something about the infinity ? http://www.amazon.com/Harder-Steenbeck-Infinity-126544-SprayGunner/dp/B010XWRDSQ
  19. hello everyone i want to know if its common to paint model ship (wood) with airbrush because i not like the effect of the normal brush there is someone that paint with airbrush? i dont want to spend to mach money for something that it will be useless for me best regards Michael.
  20. hello everyone I thought of the idea and it works great ! 1.make a photocopy of the bulkhead from the plans with the lines (of the center and WL) 2.now you need to paint the other side of the copy on the direction of the lines from the copy side by PENCIL 3.put the copy on the bulkhead with the lines outside and the pencil "paint" inside 4.Now take a ruler lay it on the line and just mark the line with a pencil 5.by doing step 4 when you marking the lines on the paper you also marking under the paper Because the other side "paint" by pencil best regards Michael.
  21. hello im working on the rattlesnake (model shipways) now i need to line the water line on the bulkhead(Horizontal line) and the center line (vertical line) is there some way how to mark the lines of the center (vertical line) and the water line (Horizontal line)? i mean how to copy the lines from the plans thank you, michael.
