Ashen
Everything posted by Ashen
  1. Hi Lamarvalley, I did the same as you, no nails and staggarded plank, I think you'll find it will work well! In regards to bending planks, is it quick and/or easy to soak and clamp around a can? I used a method of soaking in boiling water, then bending it with a soldering iron. Later on I found a laundry iron also worked and was reasonable quick. I'm not sure if this is the best way as i'm not an expert, but it seemed to work. Hope to see more updates soon. Ashen
