KeithAug
Everything posted by KeithAug
  1. like a number of you I have been considering options for installing featherboards on my saw. In particular I wanted something to provide horizontal pressure to hold the timber against the fence. I also wanted something which had a degree of self adjustment (to avoid resetting every cut). The attached photos show my solution. The arm is spring loaded (elastic bands) and this allows me to rip over a range of 1/2 inch without resetting. To reset I move the arm to the next hole, this takes about 30 seconds. The mechanical advantage on the arm means that the force holding the timber agains the fence is about 50% greater than the force applied by the elastic band. While the elastic band may appear to be a bit crude it actually works very well and of course has the advantage that the force can be varied by simply adding or removing elastic bands.
  2. Thank you for the advice - contact successfully established through the PM route. Keith.
  3. Hi Guys - I need some help! I have been attempting to buy a Byrnes table saw using the Byrnes web site and have also tried to contact Model Machines using their web site email page. When I try to use the web site check out I get "Safari can't verify the identity of the website "host2interwebinc.com" and if I try to proceed further I get a 404 error web site not found. Also I have sent 2 emails via the web page but have had no reply. I know Jim uses the NRG site and that lots of you have had contacts with Jim in the past. Can anyone suggest an alternative method of contacting Jim or Model Machines. Regards Keith
