BadMama
Members-
Everything posted by BadMama
Thanks for the kind words and encouragement, however I am back with more questions. The first involves the bearding line and how to develop it, Do I need it to create a rabbet? I have read all the tutorials here, and reread most of the Swift build logs. I also have read How to Build First Rate Ship Models from Kits and Planking the Built up Ship Model. I checked the cross sections of my plans and the 2 1/2 pages of written instruct ions. I am stumped. Also on the cross section that depicts a straight line, midway the top and bottom and from stem to stern, is that the water line and where I install the master strake? The three photos below are the bulk of my plans, the other 2 pages are for the sails and masts and rigging. I do no want to make any more major mistakes. Also reinstalled my upper deck and got a much better alignment.
Thanks guys. Used a very small bottle for alcohol application, a couple of sewing needles to open the glued joints, a couple of dull knife blades to use as pry bars and my steam iron to help soften the glue. Armed with these items 2 1/2 hours later I was able to remove my deck intact with minimal damage to a very small area of the deck near the bow. Hooray!!. Will be extra careful putting it back on. It helps that the deck retained almost all of its curves.
Worked out most of the kinks on the stern block. Didnt use the balsa, tried a paste mixture of wood filler, sawdust and glue. It came out a little harder than I expected but i was able to get a better shape. I will know better next time.Oh Horrors!! I glued my upper deck after checking the position several times. I thought I had it in correct position. I planked it and while staring at it off and on for a couple of days while reading up on fairing and planning my planking, I rehecked my deck and discovered it is 2mm off. The right (starboard) side is 2mm greater tthan the port side. Although I feel like an idiot, I'm sure somebody out there may have made the same or similar error and might have a suggestion on how to rectify it. What I came up with was: a) try to remove and reset the deck (probably would take forever and possible damage; or b)try to make shims for each bulkhead to even out the sides. Are there any other options?
Well after 2 days and numerous failed attempts, I think I finally have something that kind of resembles a stern block. Its not pretty, but the plans I have were no help. I used the info in the NRG section and some pictures from posted Swift builds, to try and visualize how to delvelop the four sides. I know there are some rough spots but I plan to use a very thinsheet of balsa to cover them and present a smooth surface. Any comments on how I may improve would be appreciated.
Hi guys. The Jolly Roger was a cheap plastic model I bought at Hobby Lobby to see if I would like model shipbuilding. I messed up the first one and because I dont like defeat,m I boought a second one. I faired much better. I learned two things: I like ship modeling but I dont like plastic models. The first two pics were entered by mistake. The Swift is my first build. Now to my current progress. I looked through several of the posted Swift logs (adivedog, jared,giantdog, 3sheets and grimber) I discovered that my bow filler blocks needed more sanding to bring the bow more to a point. I took my deck and temporarily banded it down to see where corrections were needed, I think it looks better now,also sanded down tops of bulkheads so they were flush with bottom of deck. My deck seems to have a slope from stem to stern, but looking at the other logs this seems to be correct. Is that right? Concerning the stern, when I put the last deck piece on it did not lie flat but on little points, is this area supposed to be flat from the front of the piece to the back? Also, in some logs they used the second piece at the tail and some didn't. Since I did I am having trouble trying to fit a block between there and the last bulkhead. Any suggestions would greatly be appreciated.
Hi Kim, job on your Jolly Roger. I built this exact kit-twice. The first one turned out pretty bad but since it was not expensive I bought another one which turned out better. I did find out that I do like model shipbuilding but not plastic. This kit wass pretty bad. it was warped, and my cat kept trying to eat the small parts (those that didnt land in my carpet). I admire you for sticking with it. I found 2 kits on Amazon for about $40. The Bluenose and the Constitution. Thet are vest iery simplisitic solid hull (no planking or other hard stuff) but gives the feel of working with wood. They made me decide to invest in a quality wood model for the challenge. Hope you continue building bigger and better ships.
- 118 replies
- jolly roger
- lindberg
Hopefully this will be a good log where I can learn a lot. I have slapped together a couple of plastic models and two solid hull childrens versions of the Bluenose and Constitution, but nothing on this level. I love a challenge. I read through many of the excellent Swift logs and the information in the Ship notes section. I learned a lot. After buying some tools at Harbor Freight (which I found on this site), I jumped right in. My keel had a slight bend so I dampened it and set weights on top for a day. While that was going on I cut out my bulkheads, and hour and two cut thumbs later I cut them out with no damage. I dryfitted them the next day, since everything seemed in line and level I carefully glued them. I'm not sure what is meant by fairing so I havent done that yet. also worked on the bow filler blocks. Never have anything before, but I used some balsa wood traced out with the bulkhead and keel. Not sure if this is how it is supposed to look. Now I am stuck on how to do the stern. There are no measurements and not sure how to make a template. Also started on false deck. Wasnt sure how long deck planks should be so I made them 40mm but when I put in the treenail details I think I did it wrong. Should they be centered on top of bulkheads if so can I do it on my main deck without it looking bad. Going to try to add some pictures. My layout might be wrong but I will work on it. ANY and ALL comments welcome.
