campbewj
Everything posted by campbewj
  1. Been way to long since I've posted anything and as I have reached a milestone I have paused to take a few pics and get them into my log. At this point the standing rigging is "complete" I'm holding off on the trucks as it seems it may be easier to put those in on an as needed basis when the lines that go through them are put in place. So now it on to constructing the spars and the hardware to attach them to the ship.
  2. Thank you for the ideas on the lightning rods and nice comments.
  3. One item I'm struggling with is the balls at the top of the mast. As I'm working on it, the needs to be some hole in the top of the ball to support the lightning rod which I envision being a small brass rod. There also needs to be two small holes to act as the flag halyard. Using a Dremel drill press on basswood I end up either destroying the piece or making it grossly out of scale. How have others made these pieces? looking at the other builds these parts must be done much later in the build. I'd like to try while everything is still in hand on not on the ship, but could wait as well. thoughts? thank you
  4. Still working on various pieces of the masts. I've painted the lower masts as I believe these are completed. I've formed the masts, drilled holes and made a number of brass fittings. Still working on the upper cross trees. I've used the suggestion to glue some brass on the bottom of the pieces to add some strength. Shown below is my Makita "lathe". Spinning with sandpaper to take round out the square basswood and remove material.
  5. Where I am today after picking this up after a summer away. I believe the deck structures are complete. I have started the masts and I'm nearing completion of the lower sections of all three masts. I need to re-orient myself to where I am and what's next. hopefully my next post will be in a week or two and not months.
  6. Working on the deck structures my general take on the use of the cast items is that I will attempt to build one from scratch and if I like it better than the one provided I will use it. If not, just part of the learning curve.
  7. Well its been a very long time since I last posted, about 18 months if my quick look is correct. A lot of work has been done over that time and I documented it with a few pictures along the way. Clearly posting is not my long suit but I'm going to try to do better this winter. For now, I'm just going to dump the pictures in and if anyone has a question on how I did things, please respond and I'll do my best to remember how I did it. I don't believe I'm one of the more accomplished modelers here, but I did think it is important to let folks know that work was continuing and I'm enjoying it at the pace I'm going.
  8. Coppering is now completed and I've mounted the ship on a scrap piece of wood. I'll replace this with something nice before I get into masts etc. that will make it difficult to turn up side down later on. I haven't decided if I'm going to make some nice wood mounting board or just buy one. On to the next level of stanchions and planking.
  9. Over the past couple of days I've cut enough strips and applied them to cover the first belt between the keel and the goring line. As with the practice strips, any movement of the tape while working with it shows up on the final product. Peeling the backing off, if you don't keep the foil side straight, makes little marks across the foil. While I've become better and limiting this, some is inevitable and I've simply accepted that. The markings from the Pizza cutter look good, better in some places than others but so far I'm happy with the outcome. Most of these strips will be under the boat and not seen often so hopefully I will continue to get better at this.
  10. I primed and painted the hull, I believe I stopped at 4 coats of the black to get good coverage. I was looking for more of base to set the copper tape than necessarily a finish coat. As the paint was drying a I spent some time looking at the work of Keithbrad80 and GAK1965. (which I do a lot). I tested out the pizza cutter to make the joint marks as well as a pounce wheel to add additional details. Ultimately I dropped the pounce wheel and simply went with the lines to outline the individual copper sheets. This simplified the jig such that I only needed slots to make consistent strips.
  11. Two final pictures before the primer hits the planks. Then it will be paint, and coppering for a while.
  12. At this point I've completed planking the decks. The main deck has been sanded, stained and a coat of varnish applied. The poop and fore decks have been sanded but not finishing yet. I'm holding off until I work on the railing a bit. Once I see how that goes together, I'll think about finishing before / after adding those details. I am concerned about adding the rails before I flip the boat and finish the hull. I've been procrastinating on putting primer over the all the planking work as I really love the look of wood. The next build might be one with a wood finish.
  13. George, thank you for the suggestion on the tape. I've found the venture tape and plan to use it shortly. I went ahead and did the planking on the main deck and I'm now experimenting with stain and varnish. while this dries, I'm trying to look ahead at the work that needs to be done before I think about planking the upper deck up front. should have some pictures to show shortly.
  14. After about 3 1/2 months I've completed the hull planking. The deck is still to come. I'm thinking through some sequencing of when I want to paint. Generally I like to paint before I have the opportunity to slop paint on the next things. I'm thinking I will paint the inner hull and probably the outer hull before I put the main rail as that will be stained. Then I can copper the bottom and install the deck. Interested in other views. One big question for those that have coppered the hull. I don't see any guidance as to how to prepare the wood to best take the copper plates. Will they adhere best to natural wood, painted wood, or some sort of "pre-treatment". coppering looks like a lot of tedious work and I'd hate to have them fall off because I didn't prepare the hull properly. State of the mode can be seen in the pics below
  15. hit a milestone today, completed the planking on the lower hull. Time to head to the hardware store for more sandpaper. I'll probably take a short pause to figure out where I am, what's next etc. it's been a good 2 months on planking with hardly a glance at instructions or blueprints. Will have to get my head back in the game so I don't miss something. I think painting the water way needs to happen soon. Of course I'll be looking at some of the other build logs for this as well.
  16. thanks for the kind words. continuing to plow through the planking. One more band below the planksheer and then on to above. I need to do a bit of reviewing logs to see how the planking in the upper Bands connect at the ends.
  17. The planking continues.... nothing terribly exciting here but have completed the "D" band
  18. Clipperfan, Thank you so much for these pictures. I have to admit I'm a bit lazy on the research side of this hobby. its too easy to get on with the build without a lot of knowledge that would improve things beyond what the kit might provide. These pictures will help to see what more I might be able to accomplish. It will take a bit of digesting as there is a lot of info in a few pics. Thanks again, Bill
  19. planking continues..... Pics below show the completion of bands D & E. I'm working from the bottom up. someone's log pointed out that they started where the first ones would be hidden by the copper. so far I'm pleased with the result. I'm debating if I should start now at the top and work down so I meet in a place that is also covered. Not too worried about it as it is all to be painted. Happy Thanksgiving to all!
  20. Getting ready to start planking. I'm holding off on the work near the rails as I'm sure I would break that along the way. based on the instructions, I've got about 3 months of planking coming.
  21. Spent some time looking at alignment from front to back and send down / build up the bulkheads where needed. I used the string method to see where things were out of alignment. I continued to use the string to lay out the bands. First using a tick strip to transfer the measurements for each bulkhead to the model. Then used the string to see where things didn't look right overall. After additional sanding etc. I've marked each of the bands on each bulkhead so the bands seem to lay out as expected.
  22. Shaped the underside of the plank sheer and rabbit for the stern. Continue to other logs to see how this works. Hopefully not too much rework in my future. Also carved the blocks above the plank sheer.
  23. working on the waterway and plank sheer. This has taken a bit of time at the bow and stern to be comfortable with how it all comes together. I've been leveraging the build logs extensively here to see pictures of other builds both in this state and further along to help anticipate what this should really look like. When in doubt I leave some things "unfinished" knowing that when I go to plank that area things will be much more clear.
