campbewj
Members-
Everything posted by campbewj
Its been about a month since my last post. I have completed the planking of section A. while there are places that my inexperience shows, overall I'm happy with how it has turned out. I have not done any sanding and I expect like the area above the whale, sanding will make a big difference. While doing this section I changed the technique I was using. Initially, I was using a jig to bend the planks into a shape that was close to what was needed and then do all the final fitting after it was bent. As I progressed through the section, the bending required more precision than this method allowed. I shifted to shaping them on the model itself. I would transfer the measurements from each bulkhead to the plank to get the width close down the length of the plank. then i'd use an iron with a lot of steam to heat and soak the plank. I'd do that for about 60 seconds flipping the plank over and being sure it was always wet. I would then clamp it to its place on the hull and let it dry overnight. ONce dry, final shaping and gluing would occur. This technique works a lot better than what I was doing before. I've seen so many Jig's on the market and in pictures, I don't see how they will work for complex curves needed on a ship like the Rattlesnake. I do see a problem that will happen when I get near the end of planking. All the clamps I'm using require access to the bulkhead. Both the binder clips and the purchased clamps that screw into the bulkheads need this access. As I get to the last few planks, what do I use to hold them in place while the planks dry. Looking for suggestions, thanks to all for their encouraging words and support, Bill
- 53 replies
- rattlesnake
- model shipways
All, Continue to make progress on the Rattlesnake. I'm better about working on the model than posting pictures about the progress. A few weeks back I completed the planking around the gun ports to where the rails would be. I haven't done the rails yet. I've done preliminary sanding and like the way things have turned out. There will be more sanding and cleaning up the ports before I would call them done but I did enough to convince myself I wasn't digging myself into a big hole. There are 4 pictures of this part of the ship. I've now started the lowing planking as well and have found the larger wood strips more difficult to work with. I'm just taking it slow, bending the strips for the bow and the stern and taking my time. More pictures to come of that part of the ship. It's slow going so the posts don't come that often.
- 53 replies
- rattlesnake
- model shipways
Glad to see some new followers. I hope to get to your builds this week to see what I can learn. I've started the planking around the gun ports. With the smaller planks and more straightforward alignment and little shaping of the planks, it seemed like that would be an easier place to start. So far so good.... Some things I've learned along the way. As this is my first planking effort, there is a lot to learn. - Its great to be doing work that makes is really look like a ship - the first few planks were pretty straightforward - Once I got to the gun ports, I debated cutting planks for each opening vs running the plank through the opening and cutting out the port once the glue was dry. There are some benefits for both. Running them through make aligning the next plank much easier. Where I cut individually and stopped at each gun port, there was a lot more work on the next strake. I've been running them through and you can see in the pics that I still have some to cut out. - Getting the right amount of glue is key. Too much and your wiping, and scraping and sanding to get rid of the excess. To little and the planks will pop off when you are cutting or sanding around the gun ports. When cutting use a really sharp knife and be very patient. - redoing work is a pain. I had to pull a plank or two after it was on the model and getting all the glue off and ready for the next one is a lot more work than double checking the original one. - The Micro-mark stand was the most effective Christmas present I can remember. I can't imagine how I would hold the model for this work without it, Highly recommend it. - I'm looking forward to the sanding and cleaning up the work. It's really hard to tell how this will turn out. I've been very careful to minimize gaps between boards but there is more variation in the thickness of the planks than I expected. With the basswood being very thin, I hope I don't sand through anything trying to make of for this. Interested in comments where you might see me going down a path that might cause issues. thanks Bill
- 53 replies
- rattlesnake
- model shipways
welcome all new followers, glad to have you on board. I went looking for your build (Pond) and haven't found it. My searching the site skills still need work but I'd be interested to follow your build. I'm trying to find others builds that are following me as well. I've now attached the wale board and sectioned off section A,B and C so I think I'm ready to start actual planking. Making use of my new Christmas present now holding the ship frame. I've also made a significant investment in binder clips to get setup for this. Other than the wale, none of the others are attached. I've measured, twice, and I think I have these sections correct. I've marked the locations and I'm about to pull off the boards and remark the center of each board for the true start/end to each section. Then it will be marking the location for each board. Hope you all have a great New Year.
- 53 replies
- rattlesnake
- model shipways
Steve, thanks for joining in, you may be the only one so far... Over the weekend I was able to complete the framing for the gunports. I've been struggling to align the bow and finally bent some wood to see how things might line up. Helped a lot to get comfortable I had things aligned correctly. So I'm thinking for about the 5th time I'm done fairing. Eventually I will be right about that. I put together a jig to bend to the shape of hull. At first glance it seems to work. I used a standard Iron and sprayed the wood a couple of time, "ironed" the piece top and bottom a couple of time and clamped it into the jig. There are some less then perfect portions but I expect I will get better at this over time.
- 53 replies
- rattlesnake
- model shipways
Since my last post, I have been working on the framing for the gun ports. For the most part is has been pretty straightforward. The biggest challenge for me has been deciding if the horizontal framing should be horizontal or aligned to the curve of the deck. Using one of the guns and some throwaway wood for temporary planking I was able to determine the correct height. For most of the middle ports the difference between horizontal and aligned to the deck is trivial, it becomes more apparent at the bow. I went with horizontal, we'll see later on if there are any regrets. I've also used heavier stripwood, than what was called for and have tried to have it set out just a bit so sanding will align to the curvature of the ship and not leave a gap in the planking. I've done about 1/2 the ports and will continue working my way to the stern. I measured and cut the horizontal pieces individually as I worked across the boat. I pre cut the verticals so they would all be the same size.
- 53 replies
- rattlesnake
- model shipways
some pictures that get me caught up to today. At this point I have a couple areas I'm working on; 1) I'm still working on the transom. Looking at the other builds, I'm trying to do some finishing work on this. I'm a bit stuck on the lettering. reading other builds it seems like MS word and some decal work is in order. Any other ideas on lettering? 2) Waterways and covering boards - You can see the waterway on the 2nd pic, still working on the covering boards. I'm thinking the covering boards in the Bow may wait until I get a bit further. I can't seem to see how this will align with planking particularly where the knighthead and timberhead are located. I suspect I have some rework to do in that area. In one of the pics I have the two pieces laid across and there isn't a great fit. I'm also not understanding why the instructions move ahead with the rails at this time. It just screams out to be something that will be broken as I move forward. I'm thinking of leaving this undone for a bit and working on the gunport framing
- 53 replies
- rattlesnake
- model shipways
- 53 replies
- rattlesnake
- model shipways
After lurking on the site for a few months taking advantage of all the great information, I'm jumping in. As I've been working on the model for a couple of months, I have a bit of catching up to do. This is my second build since getting back into modelling. I built many, mostly plastic models of ships, planes, tanks back in my younger days. Jumped into wood ship models about 2 years ago. Based on the advice on this site I started with the Model Shipways Phantom. With that under my belt I've started the Rattlesnake. I still consider myself very much a beginner. Most days I wish I had instructions like the Revel plastic models from my past. I guess that's part of the hobby and what makes a community like this so valuable. so here goes....
- 53 replies
- rattlesnake
- model shipways
