jollyroger
  • Gender
  • Location
    Indiana
  1. Thanks John! I was going to search online for pictures of wood. The link you attached is a big help.
  2. mfh, Did you get any answers on the parts list question? I am attempting to build the AL H.M.S Bounty 1:48. I can't understand the parts list. Mine is only in english. I can't match up the parts list and pictures with the various types of planks and strakes. I've used a digital caliper to attempt to measure and match but not having any success. For example The parts list shows: No. Description Qty Measurements Material in mm. 17 Planking strakes/hatch 1st deck 11 0,6x5x30 Mukali 20 Hold Planking 26 1.5x5x155 African Walnut 41 Hull planking 44 1,5x5x730 African Walnut 46 Gunwales outer planking 11 1,5x7x730 Sapelia I believe the quantity refers to the number needed of that particular part no./length. Where the measurement for item no. 17 would be .6 mm x 5 mm and 30 mm long. Each plank appears to be 730 mm total length but they are telling me I need to cut to 30 mm length and use 11 pieces? Nothing was labeled and sorted to determine which planks are which. Any help?
  3. I too am attempting to build this kit. I've owned it for more than 20 years! It sat on a shelf all that time. My question is how to identify the correct plank parts for the decks and hold. I do not see any markings as indicated in the rather poor instructions. Some of the plank parts are very similar in color and thickness. Anyone have a suggestion? Thanks!
