JerseyCity Frankie
Everything posted by JerseyCity Frankie
  1. Something I always look at in a ship model is how the ratlines are tied. In actual practice on ships that used rope ratlines the clove hitch was used for all the inner shrouds but the ends of the ratlines were not tied or knotted to the shrouds, each ratline end terminated in an eye splice. These eye splices were lashed to the shrouds with small stuff. Its my opinion that using a knot for the termination of the ratline ends leaves too big of a lump- the eye splices and lashings were more of a smooth taper that did not protrude outboard or inboard of the shrouds at all. Its an unpopular opinion I know, but I believe you should avoid knots at the ends of the ratlines altogether- unless you are working to a very large scale and then you are cursed to tie hundreds of tiny lashings on all your shrouds. A solution that would avoid the bulge of the knots at the ends would be to sew the end of your model ratline through the shrouds at the ends and use a spot of glue to anchor them. Or perhaps unlay the ratline stuff at the end and glue the fanned out strands to the shrouds? As I say, this is an unpopular opinion and I have not seen the process I have just described put to use on any model under 1/4" scale, and rarely even then, but I assure you this is how it is done on actual ships.
