CRI-CRI
Everything posted by CRI-CRI
  1. Two pics of bottom block : Wheels size 1/48 = 5 x 1.6 mm, at real size 1/1 = 24 x 8 cm (rope about 1.5 mm)
  2. Thanks Louie da fly 😀 A french expert told me that the lower block was around 1480 an archaic block articulated on a cringle (Halyard knights arrive later) I would add that a large 600 kg antenna requires four reals, even using a capstan, otherwise, hoisting would be difficult Three reals is good for the misain mast, not for the main mast Finally, the pulley followed the inclination of the mast, (8° on the Niña), that is the reason why it was articulated Later, the halyard knights followed the same angle as the mast. (Otherwise, they would break quickly) I think that such a disposition prevented the problem of twisting rope you met on your referenced model Regards, Christian
  3. Today, my two fast simulations : I should prefer the built number 2 for better transverse stability - And you ? Thanks, dear modellers 🙂
  4. Fourteenth done, 100% of this difficult step, it's a great day, plaudite amici ! 😘
  5. That's all folks, the last step will be probably installed tomorrow or later :
  6. I hope the last step of this part at afternoon, we have the best sunlight to do it successful :
