Posts posted by MarcusB_
Hello everyone,
Building this will be my first ever model build, and I see a lot of mistakes and learning up ahead. Reading all of the excellent build logs of others who have done this project before me will be very helpful and I look forward to getting on with it. I first got the idea to start this build waaay back, and got access to the plans, bought the wood that I needed and then life kind of got in the way of getting started and I never started my build log. Now things have kind of settled down and I found myself with some spare time and an itch to do something, and the idea of doing this build popped right back up.
I have a pretty limited selection of tools available, and since my budget is pretty small and I'm living in an apartment where noise and dust is a bit of a problem, I might struggle to buy everything I might want. I will make the best of it, and see what needs pop up along the way.
Since I bought the wood in the dimensions I needed, using the timber list I found here, making the false keel, keel, and keelson was just a matter of cutting the parts to length and cutting the rabbet for the keel. I made the rabbet by scraping the keel with a hacksaw blade that I cut to the correct profile using a Dremel like multitool, since this method seemed most likely to give me a consistent result. The finished pieces can be seen here.
I then moved on to cutting out the pieces for the first double frame (C). This was done by hand using a coping saw and clamping the wood to my desk as can be seen here:
Doing this I quickly learned what I had already read from others, that it is a very good idea to leave some extra "meat" when cutting out the pieces since it is very easy to cut away too much. After gluing the separate pieces together everything seemed to be working out OK. This was until I glued the two frames together to form a double frame... One side looks just fine, but the other has a lot of overlap between the pieces even though there should be none. I think this is caused by some issue with the joints between some of the futtocks. I had a really hard time keeping them square and at the correct angles. I tried using files, sand paper, and sawing as close to the line as I dared, but nothing really seemed to work really well. Both the filing and sand paper methods seemed to round over the end really easily. This is something I will have to work out how to do accurately moving forward. The overlap can be seen in the following picture (it is just as bad on the other side if you flip it over).
I have just roughly cut out the frame pieces for the next frame B, and I'm now contemplating how to move forward. I think I will just very roughly smooth out the pieces on the sides and then I have to figure out how to accurately get them cut to line on the joining ends. If anyone has any suggestions, they would be very welcome.
So far I've figured out that this is going to be a really hard, really fun project and that taking good pictures is a lot harder than it looks.
- Marcus
H.M.S Triton Cross Section by MarcusB_
in Cross Section Build Logs for HMS TRITON
Thank you very much for the replies and good advice. I will definately try to keep the patterns on for longer. I guess my eagerness to see what I had made got the better of me this time.
I have also looked at maybe getting a disc sander, and I think that might be the best and easiest way to get consistent nice ends on the frame parts for now. It will also help with other sanding jobs down the road. The two versions from Proxxon look like good alternatives and they seem to be available fairly easily here. I'm also looking into getting a draw plate in order to be able to make treenails later on.
For now I think the next step will be to saw out all the remaining frame pieces with a healthy margin of at least 1mm from the lines, while I figure out the tools that I need for the next steps. Hopefully I will be able to make pretty good progress during the weekend.
- Marcus
