asda28
Posts posted by asda28
On 10/13/2019 at 2:25 PM, Bob Cleek said:
You might consider masking with friskit and airbrushing. This can be tedious, but less so than hand painting and you'll be assured of razor-sharp edges. Search for "friskit" on Youtube and you'll find many excellent tutorials on using this masking material which is readily available at most all art supply stores.
Thanks Bob. I already hand painted it (after my cheap airbrush died on the second color). Looks as I expected, less than perfect. I will take a look at friskit, maybe I will brave enough to re-do.
Thanks GrandpaPhil, I didn't connect shields paintings and miniatures. As you correctly pointed out there are some interesting videos. Seems I will have to do it by hand, could not find any techniques to uniformly paint in bulk.
- Canute, mtaylor and GrandpaPhil
- 3
Hello everyone,
I am working on my first build - Drakkar by Amati. Part of the build involves painting 24 viking shields. Shields are round but not smooth (I've attached a picture), so even tape might not help much. The center and outer ridges are raised. Ideally, I would like to make center and ridges bronze/silver/black (whatever is easier due to paint application order) and the main body broken into halves or quarters with different colors. I was wondering if anyone can suggest a method or approach to avoid doing all of it by hand (what I mean is I would like to have straight color borders with no smudges, don't care if it is by hand or an airbrush). I found several logs on MSW with shields executed perfectly, but no method of painting was discussed. Keith (Amfibius) mentioned that he had to do it by hand, but I am afraid my hands are not as steady as his. Is there any way to create some kind of template? I was thinking of simply creating a round paper template with the hole in the center to airbrush center and ridges, but it is still leaves a problem of separating colors on the main part plus paint leaking under the paper. Any advice would be appreciated.
Gutermann Polyester thread for making rope.
in Rope Materials and parts resources
Chuck, have you tried working with Gutermann Skala? I am reading a lot of Russian modeling forums and it seems people prefer Skala (360/240/200) followed by Tera.
